Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Free 327!
Thread: Free 327!
Old 05-08-2013, 11:52 AM
ap72 ap72 is offline
Banned
Originally Posted by vinniekq2 View Post
The 327 has a shorter stroke than the 305 so it wont like the 2.42 gears.
I hope you had a brain fart Vinnie as I'm sure you're smart enough to realize that the shorter stroke has absolutely nothing to do with the gears. An equally built 327 will outperform the 305 at every rpm, even the low ones.
What should be of concern though is that this is an old worn out engine is questionable shape, on its best day it was marginally better than the 305, after years of use and neglect it needs to be freshened up.
I would only look at the 327 as a core, and for free you're still coming out ahead as long as the block is decent.
The Following User Says Thank You to ap72 For This Useful Post:
Valkyrie5.7 (05-08-2013)
