Free* Vortec heads. - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-27-2013, 09:02 PM
Free* Vortec heads.
Free, as in I traded a bunch of once-fired brass in a caliber that I don't reload for them. They're 906 castings from a 3/4 ton truck. I'm pretty sure that they have the hardened exhaust seat inserts, but I haven't torn them down yet. The engine threw a rod and bent one of the exhaust valves. Both of the rear-most exhaust bolts are both snapped off just level with the head. I know that's not an uncommon occurrence. (I worked at a Nissan dealership for about a year. The single most common repair that I did was warrantying the rear-most exhaust stud on the early 90's V6 pathfinders/trucks.)
I'm getting ready to do a 350 build for my truck and I was originally going to use a set of 487 heads. Either way, a set of heads needs to be redone. I haven't picked up a short block to rebuild yet. I missed a roller-cam ready TBI engine by about 5 minutes last week.
I figure that the price of having them cleaned and checked for cracks is worth the risk of a basically free set of heads. Even if they're cracked or otherwise damaged, I have a good base for very weird, yet very stable, lamp. And my wife will ask me "Why can I ever have nice stuff?"
Matt
Old 02-27-2013, 09:11 PM
vinniekq2's Avatar
I used to work for nissan back in the late 80s and early 90s.I installed A/C in the path finders before they left the port for the dealer ships.
Old 03-02-2013, 09:43 AM
I probably in-processed some of those! (I don't remember the techincal term for it.) I worked at a dealer for most of 92.
And now I can't find my valve spring compressor. I knew right where it was last time I used it....
About 10 years ago.
Gotta find one today.
Matt
Old 03-02-2013, 09:55 AM
vinniekq2's Avatar
you dont need a compressor to take the heads apart
Old 03-02-2013, 10:00 AM
Gotta have something to compress the valve springs. I'm a strong guy, but not quite that strong.
Old 03-02-2013, 10:27 AM
Proud LOSER
Socket, hammer, done......
Old 03-02-2013, 11:32 AM
I like to be able to find the parts I'm removing and to be able to keep small automotive parts from embedding themselves in my person. I know that's a technique that some people use, but I'm just not comfortable with it.
Matt.
Old 03-02-2013, 11:47 AM
vinniekq2's Avatar
exactly what would say
hammer socket&
shop rag and a hand,lol.
all engine builders do that
parts dont fly anywhere
Old 03-02-2013, 01:23 PM
Originally Posted by vinniekq2 View Post
hammer socket&
Lots of engine builders also hammer the damper on, but that's not the way I'd prefer to do it.
I was able to locate my compressor. It's in my uncle's shop about 100 miles away and will be here Monday. It's amazing what you can find out through facebook. I forgot I lent it to him a couple of years ago.
Matt
Old 03-02-2013, 07:28 PM
vinniekq2's Avatar
morcey2
ever put a balancer on a 283?
Old 03-02-2013, 09:23 PM
morcey2
That's irrelevant. There's a difference between having to press or hammer the damper on because it doesn't have a drilled and tapped crank snout and hammering it on just because it seems to work most of the time. I've had to cut steel with an arc welder instead of a cutting torch, but that wasn't my choice. (long time ago and it's a long story)
If the socket, hammer, and shop rag works for you, great. It's not the way I want to do it is all I'm saying.
Matt
Old 03-02-2013, 09:47 PM
vinniekq2's Avatar
If you dont know about something,just consider it new knowledge.we all learn.to post something like you "need" a spring compressor to take heads apart is quite funny.Even with a spring compressor quite ofter a hammer is needed as the springs just compress with the spring compressor pushing on the retainer.
Old 03-05-2013, 10:57 AM
Fair enough. I've used that to break keepers loose from the retainer, but I was always told to just do a very light tap specifically not to release the keepers from the valve stem.
I got them torn apart last night and they're fitted with the hardened exhaust seat inserts inserts. There's a pretty noticeable cast-in ridge just above the insert in the exhaust port. That must be the one that everyone says needs to be knocked down on the 906 heads.
Matt
Summit Racing vortec heads VS GM Performance Vortec heads jsm1847 Engine 3 05-29-2012 06:01 PM
putting 305 vortec heads on an pre-vortec 350 thor1022 Engine 11 01-12-2011 03:17 PM
Will a intake off vortec heads fit non-vortec heads nobody_1250 Engine 13 12-27-2010 05:02 AM
305 vortec heads vs 350 vortec rimracers Engine 6 04-02-2007 08:41 PM
