freeze/ oil galley plugs question - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-16-2013, 09:11 PM
andrewakessler's Avatar
So I bought a 350 sbc freeze / oil galley plug kit. (image attached)
I have the eight 1-5/8-inch freeze plugs, three 1/2-inch expansion plugs (oil galley), one 23/32-inch expansion plug (cam plug), and five 1/4-inch NPT pipe plugs (oil galley) installed. I also have the 1/2-inch plug installed under the rear main seal where the oil pressure sending unit goes.
That leaves me with four extra expansion plugs in the set, and I can't figure out where they go.
I've been trying to find a diagram for all the freeze / oil galley plugs for a sbc, but amazingly I can't find one.
Are they extras or am I missing something?
Old 06-16-2013, 09:54 PM
BOBCRMAN@aol.com's Avatar
Different year blocks use different size small plugs. Also a couple of different locations. It is normal to have a few extra left over. Heck I have several drawers of them.
The Following User Says Thank You to BOBCRMAN@aol.com For This Useful Post:
andrewakessler (06-17-2013)
Old 06-17-2013, 04:14 AM
some 400 sbc engines had 3 1 5/8 plugs in side of black most others only got 2, you'll use the 1/2 inch ones in front of block throw the other 3 away you'll also probably have a couple extra 1/4 pipe plugs too.The ones you should pull for proper cleaning are the 3 main oil galleys, the one at the back of motor toward the intake pad it would be under a head , don't forget that one for sureThe extra 2 1/4 inchers i always have left over cuz i reuse the hex head factory in the lower water drains on the block.
The Following User Says Thank You to reevislong For This Useful Post:
Old 06-17-2013, 08:28 AM
That makes me feel better. I didn't want to complete the rebuild only to find I forgot one measly plug.
Thanks.
Freeze plugs smokey626 Engine 64 04-13-2010 10:19 PM
oil galley plugs 63,68,70 muscle Engine 2 02-04-2009 06:21 PM
oil galley plugs GMR Engine 2 10-14-2008 07:47 AM
sbc front oil galley plugs. help please 406 ss monte Engine 4 01-29-2007 06:28 PM
rebuilt engine no oil pressure in oil galley bmedina103 Engine 9 10-07-2002 11:37 PM
