Freeze Plugs - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-23-2009, 10:13 AM
American Muscle's Avatar
305 Turbo-Fire 240hp
Freeze Plugs
Got a sbc needing freeze plugs and the main one need replacing is over the motor mount on driver side. What is the best way of changing it out. Theres also one out behind the starter. I have never replaced any before so im doing a little research before getting started. Any help is greatly needed
Old 02-23-2009, 11:26 AM
2 ways that I have done it - first way is using a slide hammer. Punch a hole in the freeze plug, screw in the slide hammer and pull it out. Sometimes using this method you could actually push the plug all the way into the water jacket - in this case, I was able to fish it out using a magnet on a length of wire (if the plug is steel), and then pulled it out with pliers.
Another way to do it is use a screwdriver or something else and hammer on the plug on one side, only. This will hopefully turn the plug within the bore and you'll be able to wedge or pull it out with a pair of pliers or channel locks. If this pushes the whole plug into the water jacket, see above
When installing a freeze plug, use a large socket that fits inside the plug's depression, or I've also used a seal driver that's larger than the plug to get it flush against the block (then a socket to push it in a hair). Use a sealant on the plug edges and you should be good to go once the sealant sets up.
Old 02-23-2009, 11:59 AM
freeze plug
If one is bad I would consider repacing them all- probably all the same age and exposed to the same conditions. Jim
Old 02-23-2009, 12:25 PM
boatbob2
freeze plugs......
HI,replace the plugs with BRASS freeze plugs ONLY.they will last almost forever.
Old 02-23-2009, 12:35 PM
I bought the truck after a buddy built the motor and didnt put brass freeze plugs in and now doesnt want to change them. So I got the truck off his hands. So the motor has never been drivin but its in the truck. will the motor need to come all the way out. sounds like lots of work for so little a part.
Old 02-23-2009, 01:05 PM
and they look sooo sexy too
Old 02-23-2009, 02:01 PM
What size do I need? Are they all the same diameter?
Old 02-23-2009, 04:41 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
Make sure the socket is a bit loose in the freeze plug. If it fits to nice in the plug while it is out of the block then it is going to be stuck really good when you drive the plug in. Really good!
Old 02-23-2009, 04:44 PM
weirdbeard's Avatar
1976 Ranchero GT
I can't remember.. You can just measure the hole in the block.
Old 02-23-2009, 04:54 PM
http://store.summitracing.com/partde...0&autoview=sku
Old 02-23-2009, 06:20 PM
i jsut replaced the same feeze plug on my motor. this is the way i did it. i just took the bolt holding the mount to the frame out and used a motor hoist to tilt the motor towards the passenger side just be careful not ot go too far. then you can take the three bolts out that hold the motor mount bracket to the block and on my car i had to go thru the fender well to get it out and back in. Took bout a hour to do mine its not as hard as it looks.
What Is The 'Right Way' To Install Freeze Plugs ? SCHOONER Hotrodding Basics 26 01-16-2011 10:44 AM
DO THEY MAKE "CYLINDER HEAD BRASS FREEZE PLUGS ? SCHOONER Engine 12 02-05-2009 08:28 PM
FREEZE PLUGS ~ DO YOU or DON'T YOU ? SCHOONER Engine 25 09-17-2006 06:10 PM
Freeze Plugs..... 1Fast65Elky Engine 29 02-22-2006 06:57 PM
freeze plugs regaldude Engine 5 09-07-2004 02:07 AM
