Demon carburetor Free speech parts auctions.
Bid on used parts to help fight the frivolous lawsuit filed against us.
Click here for details.
Parts currently up for auction: Don Garlits engine emblem, Demon carburetor, aluminum Hemi head, 1947 Chevy engine + suspension + parts, '30-'31 Ford headlights, '33-'34 Ford window regulator, "Power Rods" billet air cleaner top.
Mopar performance heads
Hotrodders Bulletin Board > Tech Help > Body - Exterior
  #1
Old 03-27-2008, 02:10 PM
41Ford1 41Ford1 is offline
Frenched headlights
I just finished up frenching 54 Ford headlight rings on my 41 ford. I have a set of 2.5" Round LED turn signals I want to french underneath the headlights. I was thinking of using 2.5" exhaust pipes to make the turn signal ring. Anyone have any ideas?
Old 03-27-2008, 02:34 PM
lets cut it up's Avatar
lets cut it up lets cut it up is offline
re: Frenched headlights
You can use muffler tube or metal conduit but make sure there is not to much weld bead slag on the inside of the pipe from the manufacture of the pipe because that can be difficult to smooth out if you are Frenching deep. Tim
Old 03-28-2008, 06:32 AM
F&J F&J is offline
Crummy pic, but I made my own round inserts from flat sheetmetal to get the correct ID for these 63 cadillac signals.
I did not use exhaust tube mainly because I did not have the right size.....plus what was already said about the weld seam.
Old 03-28-2008, 06:58 AM
cboy's Avatar
cboy cboy is offline
Always Learning - Moderator
 cboy's barnstar
These are tail lights but the process should be about the same. I used 2 1/4" exhaust tube. Here's a few shots. Complete fabrication detail is here in my journal. As Tim points out you'll have a weld to contend with. I ground mine down somewhat with a carbide burr and then made sure the weld was at the very top of each ring when they were tack welded in. You would have to have a very good eye to detect them in the finished product.
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "Frenched headlights"
frenched headlights on 1938 plymouth hudsondog Hotrodding Basics 4 02-27-2008 01:06 PM
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 10:30 AM
Reverse Lights and Headlights evltwin Electrical 1 06-01-2005 05:20 PM
Headlights for my 54 Chevy Pickup horvath Electrical 11 01-10-2005 07:15 AM
headlights 67rscamaro Electrical 4 03-07-2003 06:22 PM
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Copyright Hotrodders.com 1999 - 2008. All Rights Reserved.
