Thanks! Thanks Top 5 Wiki Tech Article Editors! Thanks!
Updated 11/07/08
#1
Alittle1
169 edits
#2
Crashfarmer
161 edits
#3
Powerrodsmike
125 edits
#4
Techinspector1
112 edits
#5
Oldguy829
85 edits
Read and write hotrodding how-to articles on the Crankshaft Coalition Wiki. See 100+ articles, or read The 8-sentence guide.
Hotrodders Bulletin Board > Tech Help > Hotrodding Basics
  #1
Old 02-27-2008, 08:51 AM
hudsondog hudsondog is offline
frenched headlights on 1938 plymouth
i am thinking about frenching the headlights on my 38 plymouth as i am switching to 12 volts and have to replace the bulbs anyways. i know you can buy these kits, but, would love to do my own. any thoughts? what about the chrome rings? how about the new modern bulbs with newer plastic mirrored bulb holder/reflectors out of a wrecking yard?any help would be appreciated.
Old 02-27-2008, 10:14 AM
loctite loctite is offline
headlights
I made my own for my 51 merc. Cut out some 18 gauge steel about 2 inchs wide and however long to fit around your headlights. welded it and ground it down. I also welded a piece of 1/4 inch cold roll ( round steel) to the outside edge of the 2 inch wide piece I cut. This gives it a nice round edge. I then cut a piece of stainless steel just short of 2 inchs wide and the same lenght of the piece of steel I cut to fit around the headlights. The stainless fits on the inside around the headlights to give it a finished look. If you polish it , it looks like chorme and hold its shine. You use the org trim ring to hold the headlight in place.
I have the clear headlights installed .
Old 02-27-2008, 12:29 PM
cboy's Avatar
cboy cboy is offline
Always Learning - Moderator
 cboy's barnstar
re: frenched headlights on 1938 plymouth
Got any pics you could post up? Sounds like an interesting way to do it.
Old 02-27-2008, 12:40 PM
JohnTN JohnTN is offline
I am considering converting to frenched headlights on my '39 Olds. Do the kits retrofit into the old headlight buckets without any fabrication required?
I have already converted to 12 volt and used a kit to replace the original 6 volt bulb sockets with halogen sockets. But the light beam is very diffused probably because the halogen bulb placement is not centered correctly for the original reflectors that are still in place.
So, thought a complete conversion kit would give me good beams.
Old 02-27-2008, 01:06 PM
F&J F&J is offline
Check with HAGEN rods or hagen street rods. They have some frenching kits, I don't recall if they need any fab skills or not
Reply Back to top
Search this Thread:
Advanced Search
vB code is On
Forum Jump
Similar Threads for: "frenched headlights on 1938 plymouth"
1939 Plymouth Headlights; Halogen Replacements and Missing Sockets hduff Electrical 5 02-12-2008 10:30 AM
1938 plymouth p4 perry parsons Introduce Yourself 3 07-23-2007 10:26 PM
1938 Plymouth 4-door sedan mahearn Hotrodding Basics 7 10-26-2005 08:38 AM
1938 plymouth Ted Daniel Body - Exterior 1 10-20-2005 04:52 PM
1938 plymouth captain zoom Introduce Yourself 2 06-28-2005 09:55 AM
