Fresh 383 belt squeal noise - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-29-2010, 07:54 PM
Tubbed357's Avatar
81 Monte Carlo SBC 357
I just got done building a 383 and finished breaking in the cam yesterday. Anyway for some reason when the motor is running it squeals pretty loud. It sounds exactly like squealing belts but that's not the issue. Tomorrow i am going to take the belts completely off and run it for a few seconds to see if there is any change. I was also thinking it could be the gear drive but i really don't think it would sound that high pitch and loud. Any help would be great. If you need more info just ask, thanks
Old 05-29-2010, 09:19 PM
Its probably just the belt. My carb makes an extremely high pitched noise also, but dosent sound like a belt.
Old 05-29-2010, 09:52 PM
Tubbed357's Avatar
hmm yea im honestly starting to think/hope it is cause i cant really think of anything else that would possibly make that type of noise. Hmm ill check tomorrow, maybe my pulleys arnt lined up right or i don't have enough belt tension.
Old 05-30-2010, 08:17 AM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Originally Posted by Tubbed357
hmm yea im honestly starting to think/hope Hmm ill check tomorrow, maybe my pulleys arnt lined up right or i don't have enough belt tension.
You probably just answered your own question.
Cole
Old 05-30-2010, 09:31 AM
T-bucket23's Avatar
Wiki Edits: 26
Cole
Make sure your timing tab isnt rubbing on the damper. I have seen this a few times and it makes a heck of a squealing or scraping noise.
Chet
Old 05-30-2010, 09:41 AM
eloc431962's Avatar
Wiki Edits: 37
This is true Chet, I have seen it happed also a few times.
Cole
Old 05-30-2010, 11:30 AM
DENCOUCH's Avatar
Timing tab...
Happened to me once!
...only once
Old 05-30-2010, 08:06 PM
Tubbed357's Avatar
Haha alright guys thanks for the input, ill let you know what happens tomorrow
Old 05-31-2010, 07:50 PM
Tubbed357's Avatar
Well i guess it isn't the belts haha. But i do think i know what it is, today i fired it up at night to move it a bit in my driveway and someone noticed there was sparks flying out from were the starter is. So i had someone else move the car and sure enough there was a blast of sparks that shot out from were the starter engages the flexplate. Soo my thought was that maybe the starter is not disengaging from the flexplate causing a loud squeal. What do you guys think. Tomorrow im going to try and shim it a bit and see if that helps. Its just you would think it would disengage at some point so im not sure.
Old 06-02-2010, 10:48 AM
Tubbed357's Avatar
Turns out it was the starter, i shimmed it a bit and bangg the noise was gone.
383 SBC Bearing Clearance Issues. Fresh Rebuild. V8 Super Beetle Engine 12 04-21-2012 11:00 AM
High pitch squeal noise after head repalcement in Chev 350 twistmas Engine 4 03-19-2010 05:17 PM
fresh 383 stroker.whats a good temp to run? jjsticks Engine 4 05-09-2007 05:09 PM
Fresh 383 overheat wit1010 Engine 4 05-09-2007 05:09 PM
fresh 383 - knock, smoke and a starter qs darom Engine 36 04-04-2005 04:48 AM
