Fresh 383 burns up pistons - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
Closed Thread
  #31 (permalink)
Old 11-07-2012, 05:32 PM
hcompton's Avatar
Old & Furious
Originally Posted by techinspector1 View Post
Being an old guy and having been around the block a couple of times, I see this a little differently than others on this board. I see you as an irresponsible "TAKER" like so many others in present day society. If you had any integrity or honor, you'd pony up for the fix on this motor instead letting the builder do the repairs and eat up all his profits from the job. If you're claiming you couldn't hear this motor detonate, you're a liar. Did you tell the builder that you altered the ignition timing? I'm bettin' no.
If I were the builder, I'd tell you to go pizz up a rope.
Tech must be in a bad mood today..
It kinda looks like it was built a little to tight and when it knocked a little it fried it. Not all builders bore the cylinders the same size. I bet they are under spec so the builder ate the cost.
Also do you have one of those silly rv cams. Go bigger i know its a truck but a little bigger will help save the new engine. Maybe even run this by the builder and pay for the cam upgrade will solve a lot of issues. I am reallly hoping he did not build a 383 with the stock 350 cam.
Quick reply to this message
  #32 (permalink)
Old 11-07-2012, 06:17 PM
1Gary's Avatar
Last journal entry: 383 dyno sym
You guys did see the O/P's post date pf 3/12.
  #33 (permalink)
Old 12-12-2012, 06:43 AM
Originally Posted by brad33478 View Post
fuel was fresh so it must of been timing when i screwed with it. can anyone think of other reasons for this?
I just want to run through all possible causes so it doesnt happen again
thanks for the quick responses
10to 1 compresson would demand premium fule in todays world.
Engine must have been singing to you (pinging/knock).
head design makes alot of difference also. Newer Vortec heads may help because of chamber design but looks like detonnation as stated. Lots of fuel wash indecated by carbon deposits but todays world fuel is very inadiquet for this type of compression. Fuel additives state they may raise octain rating 6 points but in reality it is maybe 1 point at best.
  #34 (permalink)
Old 12-12-2012, 10:51 AM
A classic case of putting a tool in someone hands that don't know his ^#% from a hole in the ground. If you don't know what you are doing ask somebody first. I am sure the machinist explained the build to him and told him what fuel he would have to use. Being cheap he fills it up with 87 octane gas. Unless he was running an open exhaust he must have heard it pinging. Probably with the brand new Holley bolted it on with no tuning so it was probably running lean. There is no way that the spark plugs would have read normal with that much damage.
  #35 (permalink)
Old 02-15-2014, 06:50 PM
Piston
Im sure, speed pro is a forged piston if so it would be ovil shaped till it got warmed up , bur too much timing for sure,and poor gas.
  #36 (permalink)
Old 02-15-2014, 07:14 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
This thread is over a year old, but please explain why a forged piston, specifically, will be oval out of the box, and if that's the case, where is the narrowest point and what will make it round again...I don't have a spare/new piston on the shelf to measure.
Semper Fi
  #37 (permalink)
Old 02-15-2014, 07:49 PM
64nailhead's Avatar
This may be an old thread, but it's a good one.
I think the original poster must have been deaf not to hear the detonation to cause that damage in less than 100 miles
FWIW, when I hear/read about guys saying they want to throw out their fuel injected computer controlled setup, either TBI or multiport, for a carb setup because it is 'easier' to tune, I wonder if they realize that the knock sensor isn't just a plug in a coolant port? But I have to admit that I have broke ring lands on hyper pistons due to too much timing/detonation, but I didn't try to blame someone else. I wonder how the OP made out.
  #38 (permalink)
Old 02-16-2014, 07:24 AM
Pistons are most times the biggest diameter at the bottom of the skirt, but are usually measured at the pin height and 90 degrees to the pin to size the piston with the bore. Some piston mfgs have different places they want you to measure it but that seems to be the norm.
They have an oval or "cam" grind to the diameter so that when they get to temp, they are round.
Or course, this all changes when the pistons see detonation as that will shrink a piston (not sure why) then it REALLY rattles in the bore . . . . .
THEN, you get oil contamination in the combustion process that will bring the octane down even further so that is knocks harder, etc . . .
You get the idea. Big damage at that point . . .
Take care, K
  #39 (permalink)
Old 02-17-2014, 11:47 AM
King of my Man-cave.
Those Speed Pro pistons pictured are hypereutectic, not forged.
tom
The Following User Says Thank You to machine shop tom For This Useful Post:
Camaro_Nut2001 (12-16-2014)
  #40 (permalink)
Old 02-21-2014, 09:55 AM
92hotrodhalfton's Avatar
I haven't run my vortecs yet but I read where the combustion was so efficiant initial timing was to be around 28 vs like 32 on older lower performance stock based heads
  #41 (permalink)
Old 02-21-2014, 10:11 AM
clwhoops44's Avatar
dont think thats true. i think any iron headed sbc likes 32-36.
the stock vortec certainly isnt the most efficient iron head on the market.
my 355 with dart iron eagle heads has 34 deg total timing and could probably take a little more but at 16 initial it starts to kick back on the starter
  #42 (permalink)
Old 02-21-2014, 12:14 PM
Proud LOSER
If you run your initial at 32 then were going to be reading about your blown up motor as well. Initial can be 32, assuming its locked with no mechanical advance. More likely your cam choice will dictate an 18*-20* curve, in which case your initial timing may be 14*, add in your 20* mechanical for a total of 34* (where i find vortec heads happiest)
Or if a larger duration cam you may want 16* initial with 18* mechanical bringing you to the same 34* total.
If you find it hard to start with a higher initial timing then after you have confirmed good grounds and cables, you can look at an ignition interrupt switch which is a simple and cost effective solution.
  #43 (permalink)
Old 02-21-2014, 12:16 PM
Name a GEN 1 head that has a more efficient chamber.
The Vortec head doesnt need as much timing as other heads, as they are that efficient. GM got the chamber right on the Vortec.
peace
Hog
The Following User Says Thank You to Hogg For This Useful Post:
techinspector1 (02-21-2014)
  #44 (permalink)
Old 02-21-2014, 12:28 PM
clwhoops44's Avatar
hogg,
im sure that vortec heads are the best stock head on the market. but id say new dart iron eagle platinum castings are more efficient.
there is no reason to limit your timing to 28deg just because you have vortec heads??
  #45 (permalink)
Old 02-21-2014, 12:30 PM
clwhoops44's Avatar
wait, just re-read and saw he said "initial timing at 28"
i was talking about total timing.
Closed Thread
It burns!!! TailGater Off-Topic 9 11-16-2007 11:40 PM
New Engine burns oil Animal Engine 17 10-06-2007 07:20 PM
Ken Burns: The War tfeverfred Off-Topic 11 10-06-2007 09:17 AM
This just burns me up robin58 Hotrodders' Lounge 27 03-27-2006 06:11 PM
burns water 225buick Engine 3 01-12-2003 04:16 PM
