Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh 383 compression
Old 06-24-2012, 09:16 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
You're not putting RTV sealer on the rubber gasket are you? Could be squishing it out when the manifold's installed. Other than that, if the mating surfaces are dry, crankcase pressure is the only thing that could be pushing it out IMO.
Semper Fi
