Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh 383 compression
Old 06-24-2012, 09:25 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Wiki Edits: 9
I would either install it dry with a dab at the ends or if you insist on coating the rubber gasket, let it setup/skin over before you install the manifold and cure for maybe 24 hours before you drive it. Sounds like it just slowly squishes out if the PCV is working/pulling a vacuum.
Horsepower is how fast you hit the wall.
Torque is how far you take the wall with you.
Midnight Sun Street Rod Association
