fresh 700R4, lost reverse only after 50 miles- - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 10:35 AM
wildb's Avatar
I hope someone may have an answer or suggestion, 1987 700R4 recent rebuild with all the good parts from PATC including new converter, built by GM transmission man with 25 + years experience. It has him stumpped at the moment too;
installed tranny with new converter(fluid in converter from start), did proper adjustment of TV cable, added 4qts, started engine, added 4 more qts. ran thru all gears, up to temp., checked fluid and topped off to full. road tested and shifted great in all gears. 50 miles on trans and lost reverse. 1st, 2nd, 3rd & OD work great. it feels like it wants to go in reverse, rpm's even drop a little, but nothing there. checked fluid, nice and red and on full.
any ideas???
fresh rebuilt turbo 350 transmission hardly shifts into reverse and no forward gears 79malibuclassic Transmission - Rearend 3 04-10-2011 11:00 PM
mopar 727 tranny lost reverse probable causes how to fix? mypowerwagon Transmission - Rearend 2 12-28-2010 09:29 PM
700R4 Lost Fwd and Reverse zeke5 Transmission - Rearend 4 11-16-2010 09:50 PM
TH 350 lost 3rd gear and reverse is weak junior stocker Transmission - Rearend 1 05-29-2009 04:20 PM
99 tahoe 4X4 - lost overdrive & reverse tank2323 Transmission - Rearend 1 12-27-2002 04:20 PM
