fresh air supply - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-10-2013, 09:11 PM
fresh air supply
I was fortunate enough to come across a clemco apollo 60 sandblasting hood with the 3 ft. hose. Does anybody have any recomendations for an air supply? I was thinking of teeing into the line off the compressor. I gotta keep on a budget but really value my lungs.......Steve
Old 02-11-2013, 03:06 PM
302 Z28's Avatar
DO NOT TEE off the air compressor line. As the air compressor gets hot from running it can burn crankcase oil off the piston rings which adds carbon monoxide to the supplied air
Vince
The Following User Says Thank You to 302 Z28 For This Useful Post:
Joe G (02-13-2013)
Old 02-11-2013, 06:29 PM
mitmaks's Avatar
Last journal entry: Grille
I would actually invest into fresh air system
Supplied Fresh Air Respirator Breathing Vinyl Painter's Hood System Sar | eBay
Old 02-11-2013, 07:33 PM
hp246's Avatar
Originally Posted by mitmaks View Post
I have one of these that I use for painting. Works great for paint. I would be worried about the abrasive getting into the system and destroying the motor. I've never used fresh air for abrasive blasting. I've always used a respirator, and never used sand.
Old 02-11-2013, 10:24 PM
mitmaks's Avatar
You don't want pump in same room where you paint or sandblast anyways. That's why you have extra hose that way you can have it outside spray booth, etc.
Old 02-12-2013, 06:13 PM
hp246's Avatar
Absolutely!!!! But I've found media from blasting in some pretty weird places. Paint vapors will settle pretty much straight down in the booth or be drawn to the ventilation filter, but media seems to bounce all over the dang place.
Old 02-13-2013, 08:53 PM
I did a bit of research and apparently this particular respirator is designed for use with compressed air. It is the apollo 60 hp. It does however give some guidlines for purifcation. It also came with the cooling air tube
Is shop air safe for a fresh air breathing system? 777funk Garage - Tools 15 04-18-2012 10:40 PM
Fresh Air Respirators, Hobby Air vs SAS, and how do you weld with one? (long) jtfx6552 Body - Exterior 0 12-06-2010 07:32 AM
Show off your homeade/ancient air compressor/air supply system! ChevelleSS_LS6 Garage - Tools 2 08-07-2005 07:39 PM
Fresh Air Supply Dasoldier Body - Exterior 8 03-23-2004 09:52 AM
