Fresh Air Supply
Has anyone every considered using an oxygen cylinder to supply oxygen to a mask, like ones used for medical purposes? As I was reading the posts I thought it maybe a good idea but thought I'd get some more input before trying it... what do you guys think?
so just regular hook ups like you NEEDED them the breathe would work just fine? have the medical masks that come with it that cover your mouth/nose? I just wondered cause you can get a small set up like that for 100 bucks, but an actual fresh air system runs like 400 dollars? but I guess you would never have to refill there systems like you would the oxygen cylinders.
SATA makes a really neat fresh air system. it consists of a water trap/activated charcoal oil+solvent filter with integral regulator, you wear it on a waist belt and hook up your paint gun to it.
i know its alot of money, but you get rid of the extra hoze, you get 100% clean, oilless ans dry air for painting and it doesnt rely on compressed air bottlesSATA system |
see the thing is I can get an oxygen cylinder for work, and have relatives that have all the hookups, so thats why I was going this route, I was just wondering if it would for sure work like if the masks where tight enough and what not.... I'm sure I could rig something up, just wondered if anyone else had ever used this method.
Crank up the flow and it'll work, better to have to much than not enough. just lose the little bag, plug that hole and good to go
are there any regulations or anything as to getting those oxygen cylinders filled? I mean can I just buy one and then take it somewhere and have it filled up? don't ahve to have any papers saying I need it to live or something crazy? Just thought I should find out before I buy one, makes sense I think
Did you see this thread? http://www.hotrodders.com/showthread...threadid=33243
as long as you use a mask with a valve to exhale through, like on filter half masks all the air you inhale will come from the supplies side, so weather you use a SATA regulator, Scuba tanks or oxygen cylinders you should be fine. you might considder jerry-rigging a filter mask to draw air from a plastic bag, that gets filled by your clean air sourceso you can turn down the flow alittle. also try and swing into the local hospital and get a disposable oxygen humidifier (its a plastic tank with water in it that the air or oxugen boubles through so your throat and sinuses dont dry out) it shouldnt cost more than 20 bucks. they might also have a mask with hose and bag attached...
