Fresh Engine Startup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-01-2012, 08:01 AM
I,m about to start up my stroked 409 for the first time. Its got a roller cam and valve train and I was wondering if I have to break in the roller cam the same as a flat tappet cam. Doe I need to keep the RPM up around 2500 to break in the cam?
Old 12-01-2012, 08:27 AM
vinniekq2's Avatar
no, but I would keep the rpm above 1700 for a few minutes while adjustments are being made. Slow the engine down as the tune settings are found.Hope you spent a few dollars on th e valve train,,,,
The Following User Says Thank You to vinniekq2 For This Useful Post:
dubya31 (12-01-2012)
Old 12-01-2012, 01:23 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Some additional info:
First start up
Good luck!
Old 12-02-2012, 09:01 AM
1Gary's Avatar
Last journal entry: 383 dyno sym
Got a soft spot for "she so fine my 409". Please do update when you get a chance.
Old 12-02-2012, 10:48 AM
vinniekq2's Avatar
yes,please,let us know how she runs. Did you use 2 WCFBs? The sound of the 409 is cool too. keep the RPM moderate though.
Old 12-02-2012, 02:30 PM
1Gary's Avatar
He said a stroked roller 409.Got me begging for more details too.............
Old 12-04-2012, 01:05 PM
The engine was built at Howard Race Engines in Barrie, and is a 30 over 409 block, balanced etc., Scat 4" crank, and H beam rods, Ross 11.5/1 pistons, Comp Hydraulic Roller Cam 511/521 with 4/7 swap, 817 heads redone and ports cleaned up, 3 angle valve job, comp cam springs, Harland Sharp roller rockers. I used the 817 heads rather than Eddys so i could keep the old school look of 6 Holley 94s.
I had a little set back and had to order a new fuel reg today. The original would only go down to 4 psi and I need to regulate fuel pressure at 1 1/2 to 2psi max or it will overpressure the carb needle. Just a couple days till I get the right one!!
Name:	August 30.12 004.JPG
Old 12-04-2012, 01:33 PM
vinniekq2's Avatar
is that a 474? I hope the carbs can breathe enough?Good thing you got all new valve train components. I still would limit RPM to 5500
Old 12-04-2012, 02:31 PM
r.p.m.= ruins peoples motors usually
My 409 stroker has seen 8000+ rpm. 474 ci and lots of nasty. Rpm is no problem with quality parts and assembly.
Old 12-04-2012, 05:39 PM
1Gary's Avatar
I'm liking this build.How much of a chop top??. Did you do the work yourself??.
Old 12-06-2012, 04:07 PM
Everything was done at home except the fantastic paint job. Black Pearl that shows Blue under the sun was done by Rick at 1st Class in Orillia.
Old 12-06-2012, 04:13 PM
I guess that didn't answer your question. The roof is chopped 4" and a Volvo station wagon donated its roof for the fill-in. Its channeled 4 1/2" and the rear wheelwells are raised 2"" and tubbed 5". The firewall is reversed, doors are suicided and flush fit.
Fresh built engine overheating on startup bendiesel Engine 8 11-08-2011 07:23 PM
96 3.8L GM engine dies seconds after startup 49Austin Electrical 6 11-27-2008 12:40 PM
Engine startup fatrat Engine 8 10-21-2006 04:56 PM
Engine and transmission startup help? 59vette Engine 3 04-18-2004 06:33 PM
fresh Cadillac 500 oil pressure drop during initial startup cadillacart Engine 11 01-11-2004 08:42 PM
