Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh engine won't run - I'm stumped.
Old 04-28-2013, 03:38 PM
richard stewart 3rd's Avatar
richard stewart 3rd richard stewart 3rd is offline
Last journal entry: 351W rebuild
Hi
The lifter must be on the heal of the lobe to get an accurate adjustment, to accomplish this you split the firing order, 1843 6572 now with #1 Int, at full lift, #6 Int. lifter is on the heal of the lobe ready for adjustment.Loosen the adjuster nut until you can move the push rod up & down, then tighten the nut until it wont go up & down anymore then a half turn more on the nut.
Best of all to you.
Rich
#1 cylinder Intake Valve at full valve lift .... Adjust #6 Intake Valve
#8 cylinder Intake Valve at full valve lift .... Adjust #5 Intake Valve
#4 cylinder Intake Valve at full valve lift .... Adjust #7 Intake Valve
#3 cylinder Intake Valve at full valve lift .... Adjust #2 Intake Valve
#6 cylinder Intake Valve at full valve lift .... Adjust #1 Intake Valve
#5 cylinder Intake Valve at full valve lift .... Adjust #8 Intake Valve
#7 cylinder Intake Valve at full valve lift .... Adjust #4 Intake Valve
#2 cylinder Intake Valve at full valve lift .... Adjust #3 Intake Valve
now the exhaust
#1 cylinder Exhaust Valve at full valve lift .... Adjust #6 Exhaust Valve
#8 cylinder Exhaust Valve at full valve lift .... Adjust #5 Exhaust Valve
#4 cylinder Exhaust Valve at full valve lift .... Adjust #7 Exhaust Valve
#3 cylinder Exhaust Valve at full valve lift .... Adjust #2 Exhaust Valve
#6 cylinder Exhaust Valve at full valve lift .... Adjust #1 Exhaust Valve
#5 cylinder Exhaust Valve at full valve lift .... Adjust #8 Exhaust Valve
#7 cylinder Exhaust Valve at full valve lift .... Adjust #4 Exhaust Valve
#2 cylinder Exhaust Valve at full valve lift .... Adjust #3 Exhaust Valve
