Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh engine won't run - I'm stumped.
  #21 (permalink)
Old 05-01-2013, 10:15 PM
bygddy bygddy is offline
Proud LOSER
Try dropping a touch of oil down the plug holes and then confirm your dist is right, and start over. I'm wondering, and could be dead wrong, but if you had exsessive cyl wash and have no compression on multiple holes it would run as poor as you described or not at all. You mentioned you had seen fuel, I'm just wondering if it was too much on fresh walls and rings and its not sealing worth a damn.
