Fresh fried tranny - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2002, 01:55 PM
Question Fresh fried tranny
Will a improperly installed touwue converter fry a freshly built tranny or just the front pump. FMX ford tranny in a 1969 'stang
thabks
79monte <img src="confused.gif" border="0">
Old 03-08-2002, 06:09 AM
Post
Depends on how much you used it. but likely just the pump. Had this happen to me once and i got away with just replacing the pump and flushing out the entire hydraulic system thouroughly. It is easy to have the torque converter slip ahead enough to disengage from the pump on installation. i am sure we arent the only ones this has happened to. I am not a trans expert but i would say you will probably be alright with a new pump,a very thourough flush or the entire system converter, cooler etc. You probably wouldnt have driven it very far before realizing you had a problem. Best of luck!
Old 03-11-2002, 08:20 AM
Post
If your toque is not seated all the way into the pump housing most likly it may have damaged the convertor pump drive as well as the front pump itself. examime both parts carefully and then go from there.
NOVA JEFF
