Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Fresh from the machine shop cleaning tips for engine block!
Old 08-04-2010, 05:46 PM
74chevyflat 74chevyflat is offline
i already used the pressure washer and royal industrial purple degreaser. it stripped everything clean, then the block was hot tanked , machined and pressure tested. i just want a way to clean it out?>
maybe some gasoline?? diesel works good as a temporary fix to keep the surface from rusting i know cuz the rods have been sprayed with it after shot peening and mounting the pistons. still no rust, and also the cylinder head was sprayed with it. anybody???
