Fresh from the machine shop cleaning tips for engine block! - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 08-04-2010, 05:40 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Originally Posted by 74chevyflat
if wd40 is scarce, what could be used in its place?
I agree that the surface rust you will no doubt get will not be harmful, it pretty much wipes off as long as the surfaces are not left exposed.
I use ATF. It's fairly thin and can be further thinned w/mineral spirits for spraying from a pump spray bottle.
If you use STP, be sure to remove every trace of it from the cylinder walls before assembly.
  #17 (permalink)
Old 08-05-2010, 09:34 AM
thank you all for your help. i think ill use the atf fluid and mineral spirits which i actually have laying around and ill coat the cylinders with engine oil every few days until i get this puppy`s cam and lifters. thats all i need at this moment should get them in a month or so but . the assembly lube is what i really need right now. could i assemble and torque the crank and rods? what assembly lube wont go dry for about a month or so?>
Confessions of an autobody shop owner. How to pick a shop to have your car restored. MARTINSR Hotrodders' Lounge 27 01-29-2010 02:22 PM
How to tell if a shop is good or reliable MARTINSR Hotrodders' Lounge 48 12-31-2007 08:42 PM
Need Help finding a Good Machine Shop RoadKing96 Engine 2 12-30-2007 12:46 PM
Machine Shop Questions? TheBigDeal Engine 1 12-28-2007 05:03 PM
Block / heads cleaning tips DoubleVision Engine 6 10-25-2002 01:47 PM
