-   -   Fresh from the machine shop cleaning tips for engine block! (http://www.hotrodders.com/forum/fresh-machine-shop-cleaning-tips-engine-block-180081.html)
74chevyflat 06-25-2010 04:58 PM
ok Ive sent my 200 inline six to the machine shop to clean up the block with .040 pistons cam bearings milled deck and i also included the head to cut the valves and seats meanwhile milling the head .040. to increase compression after deshrouding the valves and porting the bowls. I was just wondering how can i fully clean the block and headsprior to assembly to ensure that everything is Spick And Span??? maybe some bottle brushes wd-40. anyone have any tips on this???? cleaning the hardparts prior to assembly i mean. oh and painting the outside i know is a no brainer with brake cleaner.
DoubleVision 06-25-2010 05:15 PM
Use a toilet brush and sea foam or any high power cleaner on the bores and scrub them good. Use WD40 and a paper towel to check them, if the towel shows gray the bores not clean. To clean oil galley`s and small passages I use a gun cleaning kit.
BOBCRMAN@aol.com 06-25-2010 05:57 PM
X-2 a good detergent. I use lemon dishwashing detergent. (easier on flesh). Clean, clean and spray clean stuff with WD-40 or a anti-rust coating.
a1supersport 06-25-2010 11:34 PM
Agreed on the WD40 or anything similar. I start spraying WD40 as soon as I turn off the water. The faster that water's lifted from the bare metal, the better.
74chevyflat 08-02-2010 04:33 PM
:confused: ok i have royal purple, ive heard laundry detergent works good?? what about dishwasher detergent?my machine shop reccomended diesel fuel right after washing.Btw i finally have my block back all thats left to get is the timing chain, camshaft, springs and gasket set.
cobalt327 08-02-2010 06:49 PM
If you use any waterborne cleanser- dishwashing liquid is my personal choice- the cast iron will literally begin to rust before your very eyes. You have to start spraying the WD40 or ?? while the block is still damp.
You will rue the day you EVER got diesel fuel all over everything- do not use it! The smell is obnoxious and permeates everything- including your skin. And forget dishwasher soap. IMO it dissolves too slow/hard and is gritty.
techinspector1 08-02-2010 07:02 PM
Next motor, clean the block at home or use a shop that does not use a chemical that will eat out the cam bearings. Cam bearings do not need to be changed on every rebuild. Inspect and proceed.
cliff tate 08-02-2010 08:30 PM
block cleaning
final clean on cylender walls us engine oil on a soft rag it will clean,and stop rust cliff
74chevyflat 08-02-2010 10:23 PM
the block had been hot tanked before boring, i was just wondering a solution to mix up to wash it all out with. maybe some mineral spirits mixed with some tranny fluid? or buy a gallon of wd40 and use my insecticide sprayer and a cement mixing tub underneath. all i wanna do is rinse it out and fully cleans the bores. what about gasoline?? :nono: :pimp: lmao. id kill myself smoking a ciggarette. lmao. any suggestions. wd40 i think would be the best thing. and assembly lube could i put the engine together minus the camshaft and have it sitting for a while with a good kind of assembly lube> ifo what brand and type? stp? lucas oil treatment??
SSedan64 08-03-2010 02:33 AM
I use Castrol Super Clean, Greased Lightning or similar cleaner & toilet brush. Then pressure washer. If you are going to store the engine for a while use something thick like STP oil treatment brushed over all metal surfaces to prevent rust. It wont run/drain off like engine oil.
adantessr 08-03-2010 09:48 AM
I'm with ya 100% on this cobalt . Can't beat Dawn , if they have it in Puerto Rico . Worked heavy equipment 20 + years . Cannot get rid of diesel fuel smell . Wash clothes 3 or more times and smell is still there .
74chevyflat 08-04-2010 04:43 PM
yes we have dawn and actually its the only thing i use to wash dishes.when the dishwasher is out of creme cascade. i just need to know what will keep the water off the cylinders as i clean them out one by one?so i dont risk getting them rusty. i have a 5 gallon compressor and air pistol. i was only asking about the diesel to use it to lift the water off the surface. Does anyone have a fool proof way to absolutely clean a block without ruining 500 bucks worth of machine work. on the deck and cylinders.??
74chevyflat 08-04-2010 04:46 PM
i already used the pressure washer and royal industrial purple degreaser. it stripped everything clean, then the block was hot tanked , machined and pressure tested. i just want a way to clean it out?>
maybe some gasoline?? diesel works good as a temporary fix to keep the surface from rusting i know cuz the rods have been sprayed with it after shot peening and mounting the pistons. still no rust, and also the cylinder head was sprayed with it. anybody??? :confused: :confused: :drunk:
adantessr 08-04-2010 04:50 PM
In the little bit of time while you are cleaning the engine you won't get anymore rust than will wipe off with a little WD40 and a soft rag . Just don't trust the WD40 to protect for storage . Wipe it down with motor oil or preferably STP after you are done cleaning and drying with the WD40. It will be fine . BTW . blow the water out of the oil galleys ! :D
74chevyflat 08-04-2010 05:31 PM
if wd40 is scarce, what could be used in its place?
