fresh rebuild and motor wont stay running when put into gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-07-2012, 02:16 PM
I recently put a fresh trans in my car then decided to rebuild the motor. Finally got it started today and it runs and idles and revs up just fine however when I put it in gear it will stall out what could be causing this?
Chris
Old 03-07-2012, 07:12 PM
Chris
Assuming this is an automatic, you need to set the idle with the transmission in gear, it will need about 5-600 RPM.
Now if you added a big cam you might find that it can't idle that slowly and in the process of bringing the idle speed up if it has a stock stall converter the car will want to pull ahead against the brakes, then you need to consider a higher stall speed converter or a calmer cam.
Bogie
Old 03-07-2012, 07:24 PM
Idle
Ignition timing will cause the problem your having. Connect your timing light and with the engine idling watch the timing to see if it changes as you slowly raise the idle about 300-400 rpm. If it changes you need to recurve the distributor so the timing stays steady at idle and 300-400 rpm above idle.
Ron
Old 03-08-2012, 09:43 AM
Are you sure it's not the transmission?
350 chevy wont stay running powell0431 Engine 9 12-08-2011 07:33 AM
454 TBI wont stay running. Stuk4x4 Engine 2 06-22-2010 03:45 AM
454 rebuild wont stay running Ignitrous Engine 2 03-16-2010 08:07 PM
95 LTl wont stay running chevy_boy704 Hotrodding Basics 6 03-21-2007 07:43 AM
why wont it stay running 67bird Engine 10 02-12-2004 11:35 PM
