fresh sbc 350 build 400 hp poss? - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-16-2009, 01:55 AM
jasont/a83's Avatar
slave to engines
hi im jason i just built a 350 for my lil bro for as grad pres
was wondering if my combo is a good setup here is what i have
1984 trans am aprox weigh 3200 lb with driver
7004r with 3:42 gears
cam ... comp cams extreme energy 12-213 3 h292 244 dur lsa 110
1973 010 hi nickle block 4 bolt main
416 heads fully ported polished "stock valves" intake runner size 2 1/8 X 1.50
200cfm est valve size is 1.85 1.5
bowl blended valves un shrouded removed all the flashing in the exhaust ports
heads are 58cc with a .015 head gasket hit 220 psi in all 8 thinking that's 12:1
pistonsare flat tops are h345np hypers with chrome molly rings
rods are powder metal rods like 1 up from stock like an lt1 rod no name on them
total piston and rod weight are 920g
crank is steel out of a 283 49 lb
the stall in the trans is a 2800 from what i was told from a trans shop cause
the car was a 305 hard to believe that
intake is a edlbrock dual plane rpm air gap performer with a bg speed demon 660 cfm carb
pertronics ditro with accel coil acdelco 45ts
so hopin to hit low 12s
Old 03-16-2009, 03:53 AM
techinspector1's Avatar
Wiki Edits: 326
jason, I don't know what to say.
First you tell us you built a 350. Then you tell us you used a 283 crank. With a stock 4.000" bore in the block, that would make a 302 (that's if you could still find spacer bearings). Bored 0.030" would make it a 306. Then you tell us that you used 350 pistons (H345NP's that have a 1.540" compression height). A 283 crank with 5.7 rod and 1.540 piston would make a stack of 8.740", a little more than a 1/4 inch from what it should be to make a real motor. Now, you could have used a 6.000" rod with a 2.000" big end, but that would put the stack at 9.040", or about 0.015" popped out of the deck at TDC with a nominal block deck height of 9.025". You could still do that with a 0.015" gasket until you started the motor. You'd have zero piston to head clearance and all 8 pistons would crash against the bottoms of the heads and the whole shebang would go downhill from there. About the best you could ever get for static compression ratio with flat-tops in a 302 with 58cc heads is 9.78:1, so now you're telling us that you recorded 220 psi with a 12-213-3 cam that closes the intake valve at 74 degrees ABDC?????????
I was your age once.
Old 03-16-2009, 04:40 AM
jasont/a83's Avatar
slave to engines
type o sorry was a 350 crank and yes the cranking pressure was 220
and i did have my engine decked at 0 so when the piston sat in there it was flush with the top of the deck no down the hole bull**** 3.48 x5.7
was the rod and stroke .. as i mentioned the duration at .50 is 244 av is 292
seat to seat
i did all the work i pressed in the pistons in to the rods boy that was fun for doing it the first time have to be quick with that piston pin keep that thing cold the rod nice and hot not glowing never done it before. and i wasn't going to pay some one to heat something up and do the same thing i read up on it and did it only ruined one piston it expanded cause i got the pin stuck in there and over heated the piston and it expanded to 4.030 at the bodom top was still 4.000
btw the engine runs as of yesterday 7:41 pm 03/15/09
found a leak in the front seal .. but it ran real good mini starter has a hard time turning it over think its the starter it self
dose any one know how to get one defective one returned i called and emaild a week ago and they arnt there or something powermaster 9600 starter... ?
ill post a youtube link of the engine running i have a before one ... its really sad
http://www.youtube.com/watch?v=3g-mNPQldX4
thats a before ... i found what that noise was u can hear it when i rev ... every rod barring and main was spun the crank had a 1/8 in groove in it .. pic here
http://viewmorepics.myspace.com/inde...ageID=51739184
and this one too
http://viewmorepics.myspace.com/inde...ageID=51739173
Old 03-16-2009, 05:40 AM
DoubleVision's Avatar
This a drag car or street car or both?
Was the 700R4 beefed?
Does the car have T tops?
Is the rear the 7.5?
Old 03-16-2009, 02:02 PM
jasont/a83's Avatar
slave to engines
yes both mostly street
700r4 is stock running an extra cooler
yes has t tops
i dont think the piston is going to kiss the head considering the compression distance and ring position i copyd a circle track setup i wish i could of used 1.94 too but dident have the money for it. will be getting a set of dart pro 1 heads this summer
i will be welding in a full roll cage and tying it in to the sub frame connectors
i haven't set time yet
Old 03-16-2009, 02:11 PM
Banned
piston to head interference has little to do witht he height of the top ring land. If you're truely at zero deck running a .015" gasket you will be buying pistons, rods, and bearings long before you get those heads... Long before you actaully get the car to the first gas station. No one is crazy enough to run that tight of quench on a SBC.
Old 03-16-2009, 04:05 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
That much cam with smogger 305 heads? IMHO, you'd be better off waiting until you have a decent set of heads before even running it.
And, you need to rethink your 0.015" piston to head clearance.
Just use a good quality composite head gasket in the 0.040" neighborhood and you'll be spot-on, quench-wise. It's a no brainer, guy!
Old 03-17-2009, 12:16 AM
jasont/a83's Avatar
slave to engines
engine is working good set the time at 32 deg till i change plugs to r42ts
temps are good sits at 200 on the highway 160 at a stop think my radiator is too small for the engine its a single core i will be upgrading that..
i do like the tight quench must not be at 0 like i thought it was i did have it milled but that's when my dad had it and the machine shop went out of bis
should be like 9.24 i only had them surface it to make sure it was flat
i remember it wasn't much tho when i put the pistons in the piston sat flat with the deck tho ... ?
Old 03-17-2009, 08:24 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
[QUOTE=jasont/a83...with chrome molly rings [/QUOTE]Chrome rings or moly (plasma or filled) but not both.
There are steel rings but steel rings have to be coated so they will not scuff. That's where the chrome, moly or gas nitriding comes in.
One last comment on your head gaskets- IMHO, you should re torque the heads after you've heat cycled the engine a few times. Steel shim head gaskets are fairly unforgiving in this regard.
Old 03-17-2009, 01:09 PM
jasont/a83's Avatar
slave to engines
ive noticed i have a coolent leak on one side im going to todo tonight ..
Old 03-17-2009, 02:41 PM
jasont/a83's Avatar
slave to engines
another thing is wont rev past 4000 i have a hei disto and a demon carb
was fine before engine blew now it wont rev just sorta stalls there @4000
can u blow a power valve on a demon carb cause it has backfired thu there a few times ?
Old 03-17-2009, 08:42 PM
jasont/a83's Avatar
slave to engines
well found out that a 650 is too small i put a 85 jet in the main and dident make a difference any one want to buy a carb...? going to a 800 cfm cause of the intake im running is a dual plain ..
Old 03-17-2009, 09:48 PM
Greg T's Avatar
www.krusinklassics.net
Jerk those stupid heads off of there and get a set of mid 90s ported vortecs. The 64cc chambers will get your static compression down to something that will live on the street and you'll even gain about 40 horseys to play with.
Old 03-18-2009, 01:02 AM
so far no one has said if his combo could make 400 hp
Old 03-18-2009, 06:18 AM
Banned
No. not with those heads. If they were expertly gone over he may come real close, but it sounds like this enigne wasn't built by an expert (no offense intended to the builder).
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
how to get max hp and tq out of 350 sbc dustinweaver Introduce Yourself 2 01-28-2006 08:43 PM
350 sbc how much hp 54chevy22 Engine 2 08-17-2005 01:43 AM
350 heads to a 400 SBC ??? Rat Fink Jr. Engine 7 06-25-2005 11:45 AM
Broken 400 SBC flexplate with a 350 block... realsquash Engine 5 04-20-2004 11:23 AM
