Fresh T-350 , makes a pop noise, then quits moving - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-08-2010, 09:08 PM
I bought a 350 turbo from a friend. It was rebuilt by a trustworthy shop about 5 years ago and put on a shelf in his shop and never used. Never had fluid in it. I put it in my malibu, new front and rear seals just in case, and no problems. I dont think I've even put a mile on it yet. I went to back it in my shop friday night and do a little burn out and I heard a pop sound and it quit pulling. Park still works but no forward or reverse. Driveshaft is ok, tourqe converter bolts ok, linkage ok, and no fluid leaks. I havent pulled the pan yet. I hope maybe the filter dropped down. If not, can anyone tell me where to start looking or what to look for? Thanks!
Old 08-08-2010, 10:07 PM
ericnova72's Avatar
More for Less Racer
Wouldn't suspect the filter, or that it dropped down, as the fluid is high enough to still be pumped around even with the filter off. Sounds like something has broken like the input shaft/forward drum or some other hard part in the trans, or the front pump.
Old 08-09-2010, 10:34 AM
tnsmith10's Avatar
when will it rain???
theres a good chance that either the pump broke, or that the inside of the converter has stripped out.
best thing to do at this point is hook up a pressure gauge and see if you have main line pressure. gl
Old 08-09-2010, 08:31 PM
Cape Cod Bob's Avatar
So, let me get this right, u took an untried tranny thats been hangin', stuck it in and immediatly slammed it.
U tink it broke.
Old 08-10-2010, 06:26 PM
Thanks guys for the info. Started tearing into it today and havent found much. Dropped the valve body just to take a look, havent found any metal. Thats good. Did a pressure test and no pressure! Hope n its just the pump. Gonna pull it all the way out tomorrow. Thanks again guys!
Old 08-10-2010, 06:31 PM
SSedan64's Avatar
Did you intall the torque Converter correctly? Rotating back & forth while slightly pressing it in. Should hear/feel 3 clicks. If not it can break the Pump gear by the Converter & Pump drive Lugs not being aligned.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
pop noise tomthecomic Transmission - Rearend 5 10-07-2007 07:16 AM
350 pop noise (new cam, heads, ect) David03 Engine 40 12-22-2005 03:39 PM
Help Timing fresh rebuild 350 x007 Engine 4 04-13-2004 10:39 AM
350 Tranny noise, not sure what it is... Juicer Transmission - Rearend 3 10-07-2003 09:39 PM
