"Freshly Bored" '62 283 - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-25-2008, 07:18 PM
Wayne
Last journal entry: Test Fit of "new" Engine
Talke a look at these photos. I picked up the engine today from the local parts shop who farmed out the block to have it bored. Obviously, I'm not a happy camper. . I wanted to order the new bearings & rings, etc, but that'll have to wait a few more days. Oh well.........
Wayne
Name:	Cylinder 7 (a) (Medium).JPG
ID:	28182   Click image for larger version
Name:	Cylinder 7 (b) (Medium).JPG
ID:	28183   Click image for larger version
Name:	Cylinder 4 (a) (Medium).JPG
ID:	28184   Click image for larger version
Name:	IMG_2248 (Medium).JPG
ID:	28185   Click image for larger version
Name:	IMG_2250 (Medium).JPG
Old 02-25-2008, 07:58 PM
techinspector1's Avatar
Wiki Edits: 326
Did they bore it with an axe or what?
Old 02-25-2008, 09:05 PM
Good lord thats criminal.you could do a better job with a dingle ball hone and a couple years labor.
Old 02-25-2008, 10:32 PM
carsavvycook's Avatar
My 2 cents worth
Wiki Edits: 3
Pathetic. That's all that needs to be said.
Old 02-25-2008, 11:28 PM
Banned
He may have stopped the honing at the most opportune time, it looks like the block had some previous bad rusting and maybe that was as far as he could safely overbore the engine- or maybe that's wha *** looks like if you only go the amount over that you requested. What is being labeled as bad machine work could be a result of him following what he was told to do or starting with a throw away block.
Old 02-26-2008, 05:53 AM
Wayne
I took the engine to the local parts shop and said I wanted it cleaned and mic'd. They called back and said the machine shop said it needed to be bored. So I agreed and had them also install the freeze plugs and cam bearings. Don't know yet how far they bored it - hope they can go a little farther and make it a good engine. If not, I guess I'll have to use the '57 I have sitting in my shop. I'll give them a call this morning and see what happens.
Wayne
Old 02-26-2008, 05:59 AM
Will I ever get it done?
Last journal entry: Hood
That's basically what I thought when I saw it. Those rust spots look like pits that have been there for years. I do think that after the first one the machine shop should have called you to tell you either to bore it bigger or toss it.
Old 02-26-2008, 06:10 AM
FEDDO's Avatar
just bore it mor ,if you feel the need to save the block. I have had several 4'' bore 283s. I currently have one in my dragster.
Old 02-26-2008, 06:15 AM
DRS50's Avatar
Last journal entry: Epoxy primed the body today
I agree with ap72 somewhat, but any respectable machine shop that is worth their salt would have called customer and explained that it was not cleaning up at the amount requested to be bored and would have to go bigger to clean the cylinders up. The problem is the person doing the boring didnt care if it would work or not or if it was right. No Pride in their Work.And if it was a throw away block the customer should have been notified that it was not worth boring before they bored them all and expected him to pay for something that would not work.
I have had 3 blocks bored and the guy I use checks for what he thinks is the worst out of the 8 holes and starts on that one til its cleaned up, if it takes .030 to clean it then thats what he makes them all, if it takes .040 then thats what he makes them all. But he will call and tell me what he has found out.
Old 02-26-2008, 06:29 AM
1952_Chevy_Panel's Avatar
Money pit
It's hard to find a trustworthy machine shop nowadays. In my area, anyhow. If you don't tell the machinist exactly what you want done, maybe even write it down for them, it won't be done right. I've heard alot of horror stories from around here, guides pressed in crooked, completely rebuilding heads without vating(sp) or new freeze plugs. GOOD LUCK on finding a machinist that'll do what they say they're going to do. Like someone mentioned above, nowadays people don't take pride in their work, it's all about the mighty dollar. I'M NOT SAYING EVERY MACHINIST IS LIKE THAT, so nobody get their panties in a wad.
Looks like that block might have to be .060 over, anymore than that you might have some cooling issues with a daily driver.
Old 02-26-2008, 06:42 AM
CustomConspiracy's Avatar
Bored?
I don't know where everyone lives........and this may be against the guidelines but I wanna say this.
My oldest Friend in the world.........Fast Frank Hutchinson...lives in Rochester New York........and is a LIFE LONG Hot Rodder, Drag Racer, and Machinist since before we got out of High School.
This guy is psychic when it comes to engines. The other part is that he is honest to a fault!!!!!!!!!!!!!!!!!!
If you are anywhere near Rottenchester.........you should seek him out.
He lives on Portland Ave.
I do hope I didn't break any rules but there ARE competent, and honest Machinists out there.......and this guy is one of them.
Old 02-26-2008, 07:08 AM
NAIRB's Avatar
It's your block. They can't help how deep the rust is.
Many 283's will go as much as .125", so .060" is a walk in the park. If the over bore is now at .030 or something like that, try and bargain with them, and get it bored to the next size.
The rust pocks, if they are minor won't cause much issue. I know, I've got one that I run that was similar to yours. Of course, from the pictures, it's a little tough to tell how deep they are. Mine only had a couple of small spots.
Old 02-26-2008, 11:08 AM
Wayne
Called the 'parts shop' this morning and described what I found. He called the machinist that did the job and was told "the cylinders were bored to .060 and that he saw the pits and that they shouldn't cause any problems". I asked the parts shop guy to go to my house and look at the engine. He did and is calling their normal machine shop to make a determination.
Not being a machinist, and the fact that I've never rebuilt an engine before, I still find it hard to believe that these 'pits' wouldn't cause any compression or blow-by or piston-ring problems.
Will keep y'all posted.
Wayne
Old 02-26-2008, 11:54 AM
Wayne
Part shop guy just called. He called several engine shops around Albuquerque and was told that, from what he described, there 'shouldn't be any problems'. I'm gonna load it into the back of my truck and take it to a couple shops to get their opinions first-hand before I go and do anything to it.
Wayne
Old 02-26-2008, 12:16 PM
302 Z28's Avatar
"Shouldn't be any problem", yeah right That is some really shoddy work and I would not take it as gospel those bores are square either.
Vince
283 Harmonic Balancer JamesD Engine 29 03-14-2007 05:36 PM
283 stroker (307 cid) question Viking427 Engine 4 04-04-2005 10:40 PM
283 piston alternitave jeff of nc Engine 3 10-10-2003 04:33 PM
high performance 283 steve Engine 2 06-22-2003 03:25 PM
66 283 auto / 67 283 swap Question FasterPastor Engine 1 11-05-2002 12:48 PM
