Freshly Rebuilt sbc 355 cranks over hard - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2009, 05:04 PM
hey guys, i just built my first engine. It's a 1989 chevy 2-bolt main block bored .030 over. It's got a 9.7:1 compression ration and i put on new cast iron heads w/ 64cc chambers, new bearings, machined crank, rods, etc. It's all been put into a short bed 1985 S10. I put everything together, checking clearances and everything very carefully with the use of a information book on building small block chevys. I primed the oil pump before starting the engine. I just started the engine for the first time last week and it cranked right over easily when i jumped it with my jeep wrangler, putting out 14v or so when it's running. It ran, although we had to restart it a few times to get the timing right. Now when I've tried to start it up recently (maybe the 5th time or so, it started cranking over hard. Is this because the rings and valves have broken in and become fully seated and sealed and made it much higher compression? Do engines with a higher compression ratio like this usually take more volts or amps to crank over than a normal battery/alternator can dish out? Im kind of worried because it basically barely cranks over, im lucky to be able to crank it over one or two times, although that usually does start it up eventually if i take pauses in between cranks.
Old 02-09-2009, 05:16 PM
weirdbeard's Avatar
1976 Ranchero GT
Last journal entry: Almost time for the first drive!
My guess it the timing is to far advanced. Pull the wire to your coil and crank it over. I bet it will turn over fine with no spark.
Old 02-09-2009, 05:17 PM
406 bug's Avatar
9.82 @ 139mph
You may want to check your timing. Put it back where you had in on initial start and go from there.
Old 02-09-2009, 05:20 PM
Well the thing is it purrs like a kitten when started. I'll give that a try though. thanks
Old 02-09-2009, 05:49 PM
weirdbeard's Avatar
1976 Ranchero GT
My 67 Camaro liked that advanced timing too, but it was cranking over so hard I started breaking starters.
Easy enough to test though. Let us know what you find.
Old 02-09-2009, 06:22 PM
johnsongrass1's Avatar
Race it, Don't rice it!
Check your battery and grounds. these things cause all kinds of grief.
Old 02-09-2009, 06:38 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
i agree with weirdbeard on this my 408 acted the same way.oh just wondering what distributer are you running. nice 67 weirdbeard i have one to.
Old 02-09-2009, 07:43 PM
KA67_72's Avatar
I'll probably catch some grief for this, but I have a motor that likes a lot of timing also. I just have an ignition kill switch. I kill the ignition, start cranking, and flip it back on. I've tried all kinds of things short of a super starter. The old girl doesn't deserve that kind of money. If I retard the timing to where it will start, it just falls on it's face.
Kevin
SBC 350 superiority rebuttle...was:POWERED BY CHEVY, WRITTEN ON A FORD, (from 'Engine Oldsmolac911 Hotrodders' Lounge 50 01-12-2011 11:00 PM
SBC - Engine dies after hard acceleration CuttyGMachine Engine 9 07-07-2008 02:39 PM
How Hard To Push Stock Type SBC Short Block..?? Haulin327 Engine 5 10-09-2007 04:59 PM
Hard Starting my SBC 3Putter Engine 9 03-05-2004 12:37 PM
rebuilt 350 hard to turn rloban Engine 13 11-10-2003 07:22 PM
