Friction Shocks - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-30-2006, 11:23 PM
grapro's Avatar
Last journal entry: Baffles for my pipes
Friction Shocks
Has anyone ever built a set of friction shocks? I know that they are not expensive, but i would like to build my own, seen pics in speedway and total perf. but anyone ever did it or has any ideas?
Old 01-31-2006, 04:49 PM
woodz428's Avatar
Troll Hunter
I have built some in the past. There is no set way to build them. They are basically a friction pad (sometimes just leather) between two pieces of flat plate (shaped as needed) with a stud/bolt holding the plates against eack other with a spring. The tightening or loosening of the spring effects the amount of dampening. In the past I have made them using motorcycle parts for the friction devices, the steering stem of older bikes had a similar friction device that was used for the steering damper.
Rear Drag Shocks on a Street Car? JohnTN Suspension - Brakes - Steering 2 08-09-2005 04:25 PM
shocks erythnul Suspension - Brakes - Steering 1 09-21-2004 02:53 PM
Mustang II front shocks not "tall" enough BobbyG-39 Suspension - Brakes - Steering 8 08-10-2004 05:36 AM
What Front Shocks for a Softer Ride? Doc68 Suspension - Brakes - Steering 3 12-03-2003 07:39 PM
Connecting rod pin friction?? stereodud Engine 2 02-24-2003 02:47 PM
