-   -   Fried something in the dizzy... (http://www.hotrodders.com/forum/fried-something-dizzy-111253.html)
JJ350 03-13-2007 07:45 AM
Well, per my thread yesterday I correctly indexed my crank at 0* and did verify that the rotor was pointing to #1. My problem now is that when I hooked the coil up the wrong way Sunday I think I fried something in the dizzy. There was alittle smoke coming from under the cap. Anyway lastnight I went to start my truck and I have no spark.. Which is why I'm pretty sure the problem is in the dizzy, can anyone tell me what it could be that I fried? It's a points type dizzy. thanks.
Frisco 03-13-2007 08:07 AM
Replace the condenser. If it is bad there will be no spark or a very weak spark.
Look at the contact surface of the points. If they are not welded together they may be badly burned or pitted. Better to replace them. Check the gap.
I would have asked this question in your original post for clarity of your problem to all who read the posts.
docvette 03-13-2007 05:26 PM
Doc here, :pimp:
See your SECOND THREAD..
Doc :pimp:
Sean's 03-14-2007 08:43 AM
Yeah if it's solid state it's Toast !
Replace it .
Smoke from under the capp indicate's that your runnin a Solid state ignition .
Typical of Electronic ignition's hooked up back ward's on the coil !
I came out of my house one mornin seen somebody had pulled all the wireing out on my motor on my Baja .
Was so madd some one had touched my car that in my haste I Hooked the wire's up back wards !
Poof black smoke !
Week later they did it again !
I did the very same thing , all over again ?
Go figure ! :D
Sean
