Fried something in the dizzy... - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-13-2007, 08:45 AM
JJ350's Avatar
Well, per my thread yesterday I correctly indexed my crank at 0* and did verify that the rotor was pointing to #1. My problem now is that when I hooked the coil up the wrong way Sunday I think I fried something in the dizzy. There was alittle smoke coming from under the cap. Anyway lastnight I went to start my truck and I have no spark.. Which is why I'm pretty sure the problem is in the dizzy, can anyone tell me what it could be that I fried? It's a points type dizzy. thanks.
Old 03-13-2007, 09:07 AM
Frisco's Avatar
Glad To Be Here
Replace the condenser. If it is bad there will be no spark or a very weak spark.
Look at the contact surface of the points. If they are not welded together they may be badly burned or pitted. Better to replace them. Check the gap.
I would have asked this question in your original post for clarity of your problem to all who read the posts.
Old 03-13-2007, 06:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
See your SECOND THREAD..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 03-14-2007, 09:43 AM
Yeah if it's solid state it's Toast !
Replace it .
Smoke from under the capp indicate's that your runnin a Solid state ignition .
Typical of Electronic ignition's hooked up back ward's on the coil !
I came out of my house one mornin seen somebody had pulled all the wireing out on my motor on my Baja .
Was so madd some one had touched my car that in my haste I Hooked the wire's up back wards !
Poof black smoke !
Week later they did it again !
I did the very same thing , all over again ?
Go figure !
Sean
points or HEI dizzy?? dhomsey Hotrodding Basics 7 07-28-2006 10:20 AM
Don't Get Dizzy kristkustoms Interior 4 11-19-2004 07:21 AM
fried battery OLEB97 Electrical 7 10-24-2004 12:16 PM
fried wiring DeadHalfTon Electrical 2 05-30-2004 07:43 AM
Short = Fried Computer? gatroae Electrical 6 12-19-2003 01:47 PM
