fried something i need help :( - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-01-2008, 01:01 AM
jvsapp's Avatar
just a gearhead in paradise..
Last journal entry: last ones for now.
hi guys,
i'm in some desperate need of help. my 63 nova was running fine. the 194 inline 6 would run fine no issues, only thing was i was working on trying to troubleshoot the drivers side parking, turn signal and rear light. none of which worked. passenger side was fine. while poking around under the dash, my headlight switch kinna was giving me issues so i tried to remove it to make it easier to trouble shoot. it seems i caused a spark somewhere. and now i have no power to the switch. the horn relay works(still have to troubleshoot the actual horns) but now i have no lights at all, no crank etc. i am trying to find out where i can start troubleshooting to find out where/ what i fried. i have 12v and if i use a start button to the starter solenoid direct, it cranks, but nothing to the ignition. any ideas? i think im gonna change all the fuses just to be sure, but any advice would be appreciated.
thanks, JD
Old 09-01-2008, 03:35 AM
justacertifiedtech's Avatar
or was that certifiable?
Last wiki edit: How to find an electrical drain Last photo:
Wiki Edits: 3
63 wiring diagram
http://www.stevesnovasite.com/images...l/63chevy2.jpg
welcome to wire chasing 101 lol
hope this helps you out. start by checking your fuses. when all check OK if still having issues start by finding out what has power, AND GROUND (ppl usually tend to forget the other half of the circuit) start tracing back till you find out where you lose it.
You are more than likely going to find a fuse bad. I dont think this car had inline fusible links. maybe someone a little older than me can answer that one.
I am not seeing an indication of fuse links on the diagram any where.
Good Luck,
Tech
Old 09-01-2008, 10:30 AM
wiring
I believe this is one of the first years that they used a resistance wire or fusable link. I beleive everything feeds off this wire that is usually a red wire that hooks to the battery terminal on the starter. If it looks like its been hot it could have burned intwo. I can't rember if it goes to switch or fuse box first. Probably to fuse box. Check if you have power to fuse box or switch. Hope this helps
Old 09-01-2008, 10:35 AM
T-bucket23's Avatar
Wiki Edits: 26
I would be you blew a fusable link as stated above
Chet
Old 09-01-2008, 11:31 AM
jvsapp's Avatar
thanks for the replies, i actually have that wiring diagram already, but i colored the wires to make it easier for me on the initial reconnection(really helped). there is no HOT wire from the starter, my 77 C10 on the other hand has one. on my nova has a hot from the battery that goes to the horn relay and from there i think it goes to the fuseblock. i just really don't wanna strip all the tape from the wires, but it looks like i'll have to do that. i'm almost tempted to get a new harness from ezwiring. not too expensive and should fit the bill. i won't be able to check all the fuses till probably next weekend at the soonest possibly the weekend after. would the fusible link be in the wire wrap from the horn relay to the fuse block? or is it the one from the battery to the horn relay? is it possible the voltage regulator is trash too? i saw the spark when i was trying to "fix" the drivers side lights, but now i think only the horn is still getting voltage. the parking lights might be the ground issue, but front and rear weren't working. so i need to get the car back cranking first then i can go to the next side. any additional help would be appreciated.
thanks again JD
Old 09-01-2008, 07:53 PM
CustomConspiracy's Avatar
Burned up?
When I was putting my 65 C10back together, I saw a nice black wire when I was under the truck and I grounded it really well. I was so proud.
As soon as I put battery power to it..........and smoked the WHOLE harness.....I discovered some previous owner had spliced a short stretch of black wire onto a VERY RED wire up top.
The first most visible fried wire was the one from the battery to the horn relay.....TO THE ALTERNATOR.
I started replacing wire, and kept finding more and more smoked spots.
My point is........those wires are old and brittle from just time.....much less the heat and punishment.
I decided if I took the cheap (fast) way out it would just haunt me forever a little bit at a time so I re-wired the whole truck bumper to bumper.
Now......after miles of wire.....and trying to jam my 300 pound butt under the dash to cut and splice.......then to trace some of my mistakes and add ons..........well now that EZ WIRE or PAINLES thingy I thought was so outragously expensive looks like a real bargain!!!!!!!!!!!!!!!!
Old 09-01-2008, 08:36 PM
jvsapp's Avatar
thanks i'll have to keep that in mind. my butt is a little bigger than yours but i am hoping the fuses did their job and just popped. if replacing the fuses don't do it, then for cost reasons i'll probably be looking at the ezwire kit. i can't afford the $400 painless kit. then again maybe i should just order it and possibly be done with it if the fuses don't cut it. i would still need something for my Morris once i get around to that. the wiring in my nova is actually still in good shape. it surprised me for being 45 years old. nothing too brittle or cracked. then again probably wouldn't compare to current technology. anyways will get a look at it and see where it's gonna lead me.
thanks again, JD
Old 09-01-2008, 08:44 PM
jvsapp's Avatar
i just noticed taking a second look at the wiring diagram that there is a resistance wire below the Alternator right in the middle of the diagram. is this the fusible link? it shows red/white/black on the diagram. i really wish i was closer to my car and i could be checking it now i guess it'll have to wait till the weekend at the soonest.
Old 11-03-2008, 12:43 PM
jvsapp's Avatar
figured it out. was bad fuses. the ones i put in were too low a rating. put in 10's and 20's and it's ok now. just need to figure out the drivers side blinker now.
Dixie Fried Car Show nickeldimerods Hotrodders' Lounge 0 08-24-2007 03:08 PM
Fried something in the dizzy... JJ350 Electrical 3 03-14-2007 08:43 AM
fried battery OLEB97 Electrical 7 10-24-2004 11:16 AM
fried wiring DeadHalfTon Electrical 2 05-30-2004 06:43 AM
Main bearings fried NorthStar Engine 8 02-18-2004 02:54 PM
