Friggin Lighting Problems. Please help! - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-27-2004, 04:45 PM
my350camaro84's Avatar
Smoke Tires, Not Drugs.
well guys heres my problem. I have an 84 Z29 with the H.O. 305 and I've been having real trouble with my lights. I jsut put in all new high beams and low beams yet when the normal running lights are on they both work fine but when I turn on high beams both high beams pop on and the low beam on the driver side illuminates but the other doesn't. my next problem is that my brake lights work fine but when I turn on the lights no rear running lights pop on and finally none of my interior lights (cluster panel, radio, a/c heater switch, Gearshift) will illuminate. I've been told that a faulty light switch may be the problem but it's not the easiest thing to get to so I wanna be sure thats the problem before I try and get to it. I would really love to know the answer to this because then I can get my car inspected. Thanks Alot!
Old 11-27-2004, 04:48 PM
poncho62's Avatar
Wiki Edits: 5
I would say it's a number of ground problems. Check out the grounds at the sockets and the engine to chassis grounds.
Old 11-27-2004, 04:54 PM
thanks. I never really thought too much about that. I'll clean the grounds out tommorow and tell ya what happens. but any other suggestions are welcome.
Old 11-28-2004, 06:16 PM
well I cleaned out all the grounds and poof nothing happened. all the bulbs are good and I just bought a new light switch and I'll install that to see what happens if anyone would have any idea please let me know I'm at my wits end.
