fring order for 383 mopar - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-03-2009, 09:37 PM
What way do you start doing around the disturbuter cap with the firing order???? I had it started but it back fire out of right exhaust. I thought I might have a wire cross. After moving wires around now it won't start???? I took the valve covers off the see if a vlave got stuck and everything is moving. The car ran a yr ago before I change carb and intake and now just getting back working on it. any help or info will help alot, thanks
Old 06-03-2009, 09:41 PM
ok it says MOPAR in the title, skip that.
Did you pre load the valves right? They may be moving but are they set correctly?
Old 06-03-2009, 10:01 PM
Big Chrysler, 383 Engine
Firing Order: 1,8,4,3,6,5,7,2
Cylinder Numbering Distributor Rotation:
Facing the front of engine: (Right-side front) 1,3,5,7
(Left side: 2,4,6,8
******Rotor Under Cap Spins: Counter Clockwise!!!!!
Nickhotrod33, be sure that the #1 cyl is on the compression stroke at TDC (top dead center). If so, the damper timing mark should be right around zero, give-or-take. You'll notice where the rotor is pointing which should be your #1 firing cyl. Start in a COUNTER CLOCKWISE manner numbering the cylinders off. Double check yourself.
I'm not an expert machanic and don't claim to be, but that should steer you in the right direction.
~CP~
Mopar Rears rj57 Transmission - Rearend 2 04-28-2008 06:22 PM
Firing order and Distributor colincamaro Engine 3 12-27-2006 05:27 PM
Intake manifold bolts order? nicowarrenrogers Engine 5 08-22-2004 05:31 PM
Firing order wont work delory Electrical 15 05-07-2004 12:22 PM
Meaning of the iron cross? FASTCHEVY Hotrodders' Lounge 15 03-06-2004 12:01 AM
