Frnt L. brake not releasing...? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-04-2004, 04:16 PM
New Member
I'm having trouble figureing out why my front left brake's aren't releasing all the way on my 1977 Chev. 1/2 ton p/u 2wd.
I thought maybe the piston was sticking, so i replaced the caliper, but no luck, still does it...
Would it be the metering block, or maybe something in the lines???
thanks.
-carl
Old 08-04-2004, 05:11 PM
The first thing I would ck is that the caliper slides free across the mount,if it does move to the brake line. I have seen brake lines collapse so that it is not noticable yet they won't let the fluid back up to the master cylnder. it could be the metering block but I doubt it ....but it doesn't cost anything to check that, Just remove it and clean it out good with cleaner and blow it out with a air hose. hope this helps and your problems are solved
Old 08-04-2004, 05:20 PM
poncho62's Avatar
Wiki Edits: 5
I suspect , either a collapsing rubber flex line or debris in the brake lines.
Old 08-05-2004, 04:38 AM
Ghetto Jet's Avatar
current hot rod: CTS-V
Last journal entry: Lets Get Started With the Improvements
I had a brand new Pep Boys caliper stick, maybe you just got unlucky twice.
