Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - front axle angle
Old 09-01-2012, 04:52 PM
68NovaSS's Avatar
68NovaSS 68NovaSS is offline
Moderator
Wiki Edits: 9
I'm at 7 degrees on my Bucket and it's working great. I also have my toe-in at .5".
Where you mount your tie rod isn't the cause of your problems if all is setup correctly, just a matter of choice, mine is in front on a Total Performance kit, the only issue is bending it if you bump into things.
Semper Fi
