Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - front axle angle
Old 09-02-2012, 07:03 AM
timothale timothale is offline
Wiki Edits: 27
68novass
Mounting the tie rod in the front on spindles designed for rear mounting is a problem,when making turns, the Ackerman is backwards. My brother used to race gocarts and I could feel the cart slow down in corners when the geometry was wrong. With backwards ackerman, in a turn the wheels are fighting each other, Scrubbing the tires, not perpendicular to the center point of the turn radius. If you hit a bump in a turn the tire that has the most traction takes over and the front end will dart to one side. Mustang II and other most other front steer suspensions have Pivot points, geometry design locations to produce akerman geometry. The exception was 80's Ford trucks with front steer. ackerman was only close.
(BS auto engineering, 15 years as an Auto engineer, 5 years Teaching Auto college courses).
