Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - front axle angle
Old 09-02-2012, 07:22 AM
timothale timothale is offline
Wiki Edits: 27
Wayneooo
You can improve the handling with the front mounted tie rod by heating and bending or cutting and re-welding the steering arms to move the pivot -attachment of the tie rod ends as close as possible to your wheel spokes. Ackerman needs to have the wheels pointed straight ahead, and a line drawn thru centerline of the king pin, the tie rod end pivot and intersecting the center point of the rear axle., draw a V, the rear axle center is the point of the v and the tie rod and king pins are on the lines, When you get into racing with IRS and IFS things start to change, A good friend of mine, Bruce Cambern, Retired head of Ford Racing, Had all 4 wheels on his 427 Cobra pointing different directions when he set a road course record at MIS, and won 3 firsts and one second, overall first place at the 2009 optima, good Utubes, the incar shots will make you dizzy on a big screen.
