Front axle shackles - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-25-2012, 02:42 PM
Front axle shackles
On older trucks, 4 wheel drive trucks and 60's style gassers with tube axles with paralle leaf springs is there a rule of thumb that applys to where the shackles are on the front leaf springs depending on where the steering box is located , in front of the axle or behind the axle ?
example if the steering box is foward of the axle center line do the leaf spring shackles have to be on the back end of the spring?
Steering box pitman arm and drag link will steer to the left front wheel.
Does any of this make sense ?????
Gene
Old 07-27-2012, 04:53 PM
bigdog7373's Avatar
Of course it's fast
I'd say rear but i may be wrong. What are you trying to do?
Old 07-28-2012, 10:32 AM
If I put a power steering box in my 57 Chevy pickup and mount it ahead of the axle and steer to the left front wheel can I leave the shackles at the front of the spring ?
Old 07-28-2012, 08:42 PM
As a rule of thumb, you want the fixed end of the spring the same as the steering box. Not all of them are built that way, but if it was me, I would do it that way.
leaf spring shackles on a front straight axle h0trod389 Suspension - Brakes - Steering 5 09-13-2011 06:14 AM
Spring Shackles at correct angle? Wrong Axle? 71gtx Suspension - Brakes - Steering 4 06-29-2009 03:07 PM
front axle ??? Gr8lite Suspension - Brakes - Steering 2 11-28-2005 11:50 PM
4x4 axle conversion ttb to solid front axle. Jared Transmission - Rearend 6 11-07-2005 08:50 PM
front axle ruttro Suspension - Brakes - Steering 2 07-14-2003 09:11 PM
