front brake lockup - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-22-2012, 02:04 PM
front brake lockup
recently put new calipers and pads in a 87 silverado.has been sitting for a while so it took a while to get them to work ok.ive done about 3000miles with no trouble now all of a sudden the front right piston caliper wont retreat so the brakes constantly on.ive pulled it apart and cleaned it out bit no luck.any ideas anyone?
Old 12-22-2012, 02:09 PM
poncho62's Avatar
Wiki Edits: 5
Caliper is seizing....replace it.
I would replace both front calipers.....chances are the other one is pretty rusty too
While you are at it, I would replace the flex hoses....They are old and may be deteriorating.
Ontario Rodders
Old 12-22-2012, 02:30 PM
thanks but both front calipers are brand new out of the box.thats whats got me stumped.and only one side is locking up.
Old 12-22-2012, 02:41 PM
poncho62's Avatar
Wiki Edits: 5
Chances are that one of the flex hoses has debris in it, causing it to act like one way valve, not letting the fluid flow back
Ontario Rodders
The Following User Says Thank You to poncho62 For This Useful Post:
tuatara (12-22-2012)
Old 12-22-2012, 02:43 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
One thing you can check (I've had this happen on a Blazer) is if you live in an area where the roads are salted (and sometimes in other areas) the bracket that retains the flexible brake hose on the bottom A-arm (or where ever it may be at) can rust on the ID of the bracket enough to actually pinch off the hose. This allows the brake to apply but keeps the fluid from returning to the master cylinder so the brake will drag.
I've also heard of the flex hose delaminating on the inside and blocking the flow.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 12-22-2012, 02:46 PM
Faith - Respect - Trust
Did you lubricate the caliper sliders? Where the new caliper's off shore rebuilds or a quality rebuild. A rebuilt caliper is exactly that...they needed to be rebuilt because they where faulty for whatever reason. If the caliper cylinder was damaged before rebuilding it may work for a while but will eventually fail. Many jobbers now sell more white box (cheap) rebuilds and in some cases that's exactly what they are.
Ray
The Following User Says Thank You to 69 widetrack For This Useful Post:
Old 12-22-2012, 05:01 PM
thanks mate.think it's the master cylinder now.it's back feeding into the reservoir.cheers.
Old 12-22-2012, 05:53 PM
thanks mate.ive pulled all the hoses off and blown them out with air.it now looks like the master cylinder has shat itself.getting blow back into the reservoir instead of feeding down the hose.gonna leave it till the new year now.shops have pretty much shut for the year down under.
Old 12-23-2012, 10:44 AM
S10xGN's Avatar
Gotta love a turbo!
You may be seeing your compensating ports in action. Look
. My guess is dirty fluid, I had this exact same problem with my '98 Dakota while on a road trip. Had to have a mechanic look at it, he disassembled the caliper and couldn't find anything wrong, but did say the fluid was awfully dirty. I flushed 2 QTs through my system when I got home and it's been fine since.
Russ
Old 12-23-2012, 04:51 PM
thanks for that mate.fluid was completely replaced when we replaced all front and back brakes.pretty confident now that its the master.have a good xmas.andy.
Old 12-23-2012, 05:14 PM
poncho62's Avatar
Wiki Edits: 5
Good luck...but I cant see how a bad MC could make one caliper lock up and not the other
Ontario Rodders
tuatara (12-23-2012)
Converting non-lockup 700R4 to lockup V8TEC Transmission - Rearend 7 09-10-2011 09:25 AM
th350 lockup or non lockup ratrod47 Transmission - Rearend 2 09-09-2009 03:57 AM
Front Brake help bucket head Suspension - Brakes - Steering 0 02-11-2009 08:12 PM
non lockup vs lockup converters? Sagacious Transmission - Rearend 2 03-25-2005 05:33 PM
brake lockup coolstude Suspension - Brakes - Steering 5 10-27-2004 08:56 AM
