Front brake upgrade
Hi all,
I am upgrading the wife's 33 coupe front brakes. They have 11" rotors, 78 GM calipers and they work just fine, NO problems....just ugly. So I want to upgrade to some "pretty" (her words, not mine) groved /drilled /polished rotors and calipers. I need to do this so the wife is more in tune to the changes I want to do to my car! wink wink grin The front Budnicks are 14" so 11" is about as big as I should go plus the 11" work fine. She has about 34,000 miles on them. Any reccommendations as far as brand/type? Heidts/Wilwood/SSBC/ECI/....? Thank you for your considered opinion....chuck |
I would not use the small 2 piston wilwoods, the braking will suffer a bunch. The dynalite style brake pad is about 1/2 the size of your current caliper's pad. This is the caliper that most of the aftermarket guys are selling.
Rotors are a non issue, whoever has a rotor you like in the size that fits your caliper/ hub, etc will work. Wilwood does have some bigger calipers with 6 pistons and bigger pads, maybe they have a setup for your spindle. You didn't say what spindle you are running. SSBC has some good looking calipers that work well, and are only a little more expensive than the wilwoods. Baer and Brembo are trick looking, work very well, and cost a fortune. You could check out their websites for your application. Hope this helps, Mikey
my signature lines...not really directed at anyone in particular.. BE different....ACT normal. No one is completely useless..They can always be used as a bad example |
| Chevy II Front Brake Conversion problem | Trevor Horn | Suspension - Brakes - Steering | 5 | 04-05-2007 08:10 PM |
| Camaro brake upgrade | SSon18s | Suspension - Brakes - Steering | 2 | 05-25-2006 01:40 AM |
| Brake upgrade on '47 Chev 3/4 Ton | jwvonl | Suspension - Brakes - Steering | 4 | 12-10-2005 08:24 AM |
| Wheel clunking and brake squeal | skizot | Suspension - Brakes - Steering | 29 | 10-09-2004 06:17 AM |
| front brake diagram drum brakes | 72chevyelcamino | Suspension - Brakes - Steering | 0 | 10-28-2002 02:17 PM |
