No , the newer spindles are offset differently and beyond that , ball joints arent exactly right either . When you turn them around the geometry between joints and control arms is way wrong . I had a 69 firebird with disc brakes and a thoughtful friend ditched it . I know camaro and firebird from 67 to 69 will switch . Im told the nova from 67 to 69 will work . I had power Drum Brakes on 67 that we switched to disc with a conversion kit from somewhere , I cant remember if it was Year One or The Paddock . Check both out . The 70 up Camaro is an entirely different driveline and front suspension .
