Front BRAKES Won't hold - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-13-2013, 07:33 PM
Hello all,
I have a 1966 Lincoln Continental that I am trying to get up and running..more like trying to get it to stop. My issue, Just replaced the front calipers, the rear brakes, master cylinder, and both wheel cylinders. The problem I am facing now is after bleeding the system, only the rear brakes hold. Fluid is getting into the calipers,because when I bled them,the fluid was clear and flowing.
With the pedal pressed all the way down, I can still turn the wheel by hand...even when I have the vehicle running.
At this point any help/advice will be welcomed
Old 04-13-2013, 08:48 PM
Banned
Did you bleed the MC before you installed it?
Old 04-13-2013, 10:57 PM
Yes, Bled the master cylinder before, during and even after. Even started to look at the metering valve below the master cylinder.
Old 04-14-2013, 04:29 AM
poncho62's Avatar
Wiki Edits: 5
OK...You are talking about front calipers. I am pretty sure a 66 Lincoln didnt come with front disk brakes, so I figure its aftermarket. Are you sure you have the correct proportioning valve etc to do this one your car?
Old 04-14-2013, 09:34 AM
It's actually not an aftermarket upgrade, it came with front disk brakes.
Old 04-14-2013, 10:38 AM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
IMO, it sounds like you're on the right track in suspecting the proportioning valve.
E-How
Old 04-14-2013, 12:36 PM
Thanks I hope so.
BRAKES WON"T HOLD Ossie Suspension - Brakes - Steering 3 06-02-2012 11:09 AM
Power brake system won't lock brakes Chief-e9 Suspension - Brakes - Steering 2 10-20-2011 01:25 PM
Front brakes won't bleed redneckhotrods Suspension - Brakes - Steering 2 08-14-2010 11:41 PM
New Front Brakes.. Guy Hiltz Suspension - Brakes - Steering 2 04-24-2010 02:18 PM
My 700R4 won't hold first (low) gear! Bayley Transmission - Rearend 5 05-30-2006 12:22 PM
