Front Bumper Removal!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-12-2004, 02:22 PM
zipfactor's Avatar
Last journal entry: Just starting
Hey all,
I have a '95 Dodge Avenger. In the Haynes manual it says that you have to remove the front bumper to take the headlights out. Well i noticed there were three bolts in the back of the headlight so i thought i would try getting those out so i could maybe sneak the headlight out. Well the one bolt would not come out, and both the same bolt on both headlights wont come out. So i decided that i should follow the manual and take the bumper off. When i go to get the bolts off, half of the bolts' head breaks off. I get all of the bolts off that i can see, and the bumper would not come off :-/.....there seems to be bolts under the headlights that i have to get off, but in order to get to those, i have to take out the headlights! Somebody please help!!
thanks in advance
Ben
Old 07-12-2004, 02:37 PM
why are you removing the headlight?? do you just need to replace the bulb or is the lens cracked??
Jesse
Old 07-12-2004, 02:41 PM
zipfactor's Avatar
The lens is all fogged up and makes me headlights dim so i need to clean them out
