front cam seal neon 2.0L SOHC - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-08-2010, 06:54 PM
fast68's Avatar
likes chevy trucks & boobies
replacing front camshaft seal on a 99 neon 2.0L
it is completely black neoprene
they are really bad about workin themselves out and causing a catastrophic oil leak on these engines
what could i use to help make sure the new seal doesnt work its way out?
some kind of adhesive
was thinking maybe yellow trim adhesive
not sure.
thanks
Old 02-08-2010, 07:25 PM
4 Jaw Chuck's Avatar
Loctite 518.
— Han Solo
Old 02-09-2010, 10:47 AM
fast68's Avatar
hmmm very interesting thanks!!
Old 02-09-2010, 11:33 AM
Its a non-hardening sealer designed for Aluminum, I use it for sealing crankcases on two strokes and installing all kinds of rubber seals. I find it doesn't glaze over like Yamabond once exposed to air and doesn't kick until you exclude air from the joint so the working time is excellent.
Best non-hardening sealant I have ever used and I think I have tried them all.
— Han Solo
Old 02-09-2010, 12:31 PM
fast68's Avatar
hopefully autozone has some. im gonna know here in about 10 minutes when he gets back from there with my list of parts to get.. includin the new seal..
hmm..
i need to get this crazy car back together. hopefully in a couple hours it will be done and out of here yay.
got the timing belt tensionor compressed and lock pinned and everythin else set up and ready now.
the rear timin housin cover is busted and missin a large piece where the cam gear timin mark was, so i ahve to guesstimate where the cam sprocket needs to be, pretyt much 12 o clock, i made a length of spray can nozsle tube cut to length from the fron most edge of the opening of the broken out spot back to the sprocket groove with the tmin mark on it, before i removed the belt and sprocket, when it was set to dead on, at the crank mark
so ill be fine.. since the sprocket is dowl-pinned to the cam nose end,
fun fun
hate chryslers..
thanks again
Old 02-09-2010, 05:25 PM
Let it dry overnight before you start her up.
— Han Solo
Old 02-09-2010, 05:56 PM
fast68's Avatar
hmm well., as pretty commonly... i had to improvise and hope,.
they dont have this flange sealer here in this town,, not surprised at all..
i used the yellow trim adhesive and some cursin and hopin, as i was tryin to install the stupid seal, since there is no room to use a sleeve or socket to drive it in, i had to use any utensil possible... and it still fought every mm going into place.. wow..
one side was tighter, the cam seems to be off centered
but i got it regardless..
hmm
all seems well.
all back together done and runnin great.
even got the timin set together the first time marks stayed lined up after two revs around to check it,.
miracle..
all for a lousy 6 dollar seal..
not surprised at all however
such is life,
such is the way jobs go commonly
thanks!
Old 02-09-2010, 09:46 PM
sbchevfreak's Avatar
Licenced Automotive Technician
You seem to get all the fun ones, lol! I used to curse those pee-ons. Cam seals, head gaskets, collapsed pistons (shudder) all on warranty. PITA jobs, and can you say pays crappy on flat rate warrenty time? Oh yeah, I for got electrical gremlins, water intrusion into the trunk, the list goes on..... Be glad it was just a cam seal....
Old 03-04-2010, 05:59 PM
fast68's Avatar
haha yeah i get to have the fun ones they dont want to touch here.. the puzzles etc... hahaha
but i like working by myself so its ok... ill do the fun jobs just so i can work alone
car has been gone for a while now with the owner and still doing great yay.. so apparently the new seal is going to stay in the head for good...
yay..
thanks
Thick front pan seal problem... or not?? biggeazy-e Engine 21 08-05-2008 11:17 AM
700R4 front seal KeithB123 Transmission - Rearend 2 09-19-2003 08:44 PM
IGNITION and CAM TIMING sum87mustang Engine 3 07-11-2003 07:52 PM
Front seal, small or large ? Rad Ray Engine 3 12-08-2002 02:31 PM
350 front seal oil leak buddy Engine 4 08-29-2002 05:25 AM
