front clip is off 57 3100 now what? - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2011, 06:41 PM
Got the front clip loose ready to pull it. I'm going to have to store it out side this winter (no room in the shop). Question is what needs to be done to the clip so it wont get damaged? I'm sure just pulling it setting it on pallets and covering is not good enough. Whats the best way to support it so the fenders don't get damaged?
Old 11-29-2011, 11:23 PM
ogre's Avatar
the 'Duracell Project'
keep it off the ground and don't cover it.
you can stand it on end or leave it flat.
you might want to tie it down to a couple of cinder blocks.
Old 11-30-2011, 08:01 AM
I plan on making some cross bars to hold the fenders from flopping around, so setting the clip on pallets is good enough dont need to suspend it?
Old 11-30-2011, 08:27 AM
boatbob2
outside storage ,,,,,
Hi,if you have room,make a rope cradle,and attach a pulley to the inside roof of your shop,then pull it up,tie off the rope,and its stored inside,out of the way and protected...
Old 11-30-2011, 09:37 AM
You really only need one crossbar attached to the last inner fender bolt hole on each side. That way you can leave it on for stability when you reinstall it and get your upper fender/cab bolts installed. I did mine using a measurment taken before I removed it and stored it on a pallet, uncovered.....but then I live in AZ.
Old 11-30-2011, 11:37 AM
ogre's Avatar
i had 2 guys to pull it off as a whole unit complete with radiator core support. it's quite stable as is. i say to not cover it because the cover will trap water and do more harm. mine was off and whole for 3 yrs. these trucks are waterproof...
Old 11-30-2011, 11:47 AM
I have pulled clips like that off many times, right now mine is off my truck and sitting out in the yard. Unless you do some obvious stupid thing, just removing it and setting it on a pallet of sheet of plywood or even just a slab of concrete it is going to be fine. Leave the hood off and next to it so the weight of the hood isn't an issue. But there is no need to cover it anymore than if the truck was out side, has it been covered every day of it's life?
Old 11-30-2011, 06:30 PM
Thanks for the help. I ended up puting 4x4s' under the rad support holes, a 2x4 between the rear holes of the inner fenders and 4x4s' under that. Looks like a pretty sweet peice of furnature . Not going to cover or leave the hood on.
57 chev 3100 front shock mounting vetteman Suspension - Brakes - Steering 1 11-29-2010 06:17 PM
49 3100 front shock location Prof. T. Soggmeyer Suspension - Brakes - Steering 1 12-11-2006 08:19 AM
Clip the front of a 59 Chevy pu with a 70 Camaro Front clip? Will it work? classicappraiser General Rodding Tech 6 10-16-2006 12:05 PM
Front Clip Mike Jones Suspension - Brakes - Steering 6 06-09-2006 03:57 PM
Front Suspension 53 Ford Front Clip PaulNJ53Ford Suspension - Brakes - Steering 2 08-11-2004 10:12 PM
