Front clip options for 59 Suburban - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-18-2005, 02:02 PM
garretthes's Avatar
Last journal entry: Rear Axle swap #2 (74 Camaro) part 6
First let me say the Suburban and Chevy truck have the same front end.
I was planning on using the front clip from a 79 camaro. However, I'm about to purchase an 85 Silverado for the drivetrain and was wondering if I could just use the front clip from it.
Will it fit, and if so, how would the front end sit compared to the camaro?
Thanks guys!
Old 08-18-2005, 02:33 PM
Houston54's Avatar
Last journal entry: 1954 Chevy Truck Project
You can make anything fit but will it look right. The GM truck suspension may be too wide and prevent you from lowering the truck to the height you wanted. It may also be a bolt in instead of a weld in like the camaro sub. My choise would be the camaro sub.
Good luck and let us know what you decide.
Old 08-18-2005, 04:58 PM
Lou's Avatar
Lou Lou is offline
Last journal entry: some more body shots
I really like the 78 thru 87 G-body front end Monte Carlo, Regal, Malibu, Cutlass. i've done a couple of trucks ( 55 thru 58 ) with that front end.
Old 08-18-2005, 07:43 PM
garretthes's Avatar
Sounds like there may be some front end damage on the 85 Silverado. He said it was pulling to one side pretty bad.
Old 08-19-2005, 06:08 AM
garretthes's Avatar
Between the G body and the camaro/trans am which will handle and ride better with my heavy suburban. Brake size is also important.
Old 02-19-2009, 11:02 PM
garretthes's Avatar
Update
I went with a 74 camaro front clip and 2004 Silverado drivetrain with computer. Love it.
Old 02-21-2009, 07:02 AM
Lil John's Avatar
Wanabe Mechanic
Last journal entry: 55 chevy 2nd series truck
Hey
I like it that looks nice.
Retro Front end for mid 90s Suburban rvrbrb Body - Exterior 4 04-23-2003 05:53 PM
Removal Of Front clip 72 nova? Pro1972nova Body - Exterior 1 03-02-2003 08:50 AM
Looking for some El Camino front clip parts jamiea1979 Interior 4 10-09-2002 12:59 PM
Front clip walter Engine 3 08-22-2002 02:54 PM
'70 dodge charger front clip stacey Body - Exterior 2 04-10-2002 07:58 PM
