Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front Coil Over Shocks on a Straight Axel!
Old 02-05-2013, 03:32 PM
Fe Block Fe Block is offline
Last journal entry: Coil Over Shocks on a Model A Ford
jaw22w
The more coils involved in a longer spring and shock the more vertical movement with the same impact. 10" spring moves 1" but a 12" will move 1 1/8" You use lessor weight spring but the additional movement results in the same weight after you multiply. 1 *300 or 1.125 * 275 roughly the same. I think that's how it works!!!!
