Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Front Coil Over Shocks on a Straight Axel!
Old 02-08-2013, 06:51 AM
jaw22w jaw22w is offline
[quote=aosborn;1643941]
Originally Posted by jaw22w View Post
Are you referring to the pre-load setting they have shown? Since they are showing you three different spring choices you would need to preload each spring a different amount to support the car.
No, not referring to the preload. When I input the weights and angles for my car using a 6.3" travel shock and a 12" spring, performance mode recommends a 150# spring with .47 preload. Then when I input the same numbers but change to a 4.1" travel shock with a 10" spring, performance mode recommends a 200# spring with .52 preload. I don't understand why when changing spring lengths, the spring rate needs to change.
