front coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-15-2008, 11:41 AM
cosmictbird's Avatar
good times!
Last journal entry: 64 thunderbird
front coil springs
i have just won the battle of getting my front coil springs off my 1964 t-bird. they have the look of a coil spring that has been on a car since 1964! is there a good way to clean them? a wire brush seems like it would be difficult getting on the inside. can i put a clear coat on them when i get them clean or even paint them ford blue? jegs does sell a set of coils to fit the bird but if i can use these original monsters i would. thanks for all the input and keep those beautiful cars between the ditches!
Old 07-15-2008, 03:43 PM
good times!
figured out my own problem this afternoon. wire brushing was a snap, cleaned up real nice. i would like to put a clearcoat or a finish on them however. when i compress the spring back into the suspension will i get cracks in any type of finish i might use. my engine block is ford blue and i would love to match all the coil springs to that. it's a heat treated paint for engines. any thoughts on that for the springs?
Old 07-18-2008, 06:13 AM
Hellbilly Hotrods
ive used powdercoat, spraypaint, rustoleum, por15, etc. as long as the prep work is good, and you use ligfht coats on the paint, itll hold up fine.
Michael
help me find front coil springs antirice Suspension - Brakes - Steering 3 08-08-2007 11:30 AM
Using Ring Style Coil Spring Spacer to Raise M-II Front End? acr Suspension - Brakes - Steering 2 04-03-2007 08:02 PM
Coil Springs DoubleVision Suspension - Brakes - Steering 4 06-21-2005 05:04 PM
Coil Springs replacing leafs 46ChevyPickup Suspension - Brakes - Steering 3 01-05-2005 05:11 PM
Installing New Front Springs horvath Suspension - Brakes - Steering 7 06-07-2003 09:04 AM
