Front coil springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-02-2004, 09:38 PM
Question Front coil springs
I have a 1939 International Pickup that has a front clip from a 1975 Trans Am. The donar car was a big block and the springs are way to stiff. I would like to pick up a 2-3 inch drop and still have a good ride. I do not want to use drop spindles. What springs could I use to get this done? I see that Afco has different spring rates but, I am not sure ones I need. The Pickup has a ZZ430 crate motor with a 700R4. Any help would be great. Thanks Keith
Old 04-03-2004, 05:32 AM
poncho62's Avatar
Wiki Edits: 5
1st, before you do anything, make sure that all the weight is on the front end (fenders, bumpers, engine etc) to see where you are at.
A set of regular, small block Camaro/Nova springs should be about right. Thats what I have in my 51 with a Nova clip.
Old 04-03-2004, 08:52 AM
I have a set of Nova springs and the are real light. They are 5 inch not the 5 1/2 that the spring pockets are. I will grab a set of small block springs and give them a try. Thanks Keith
Old 04-04-2004, 01:12 AM
Try some from a 6-cylinder car.
