-   -   Front coil springs 62 impala (http://www.hotrodders.com/forum/front-coil-springs-62-impala-202870.html)
itsandre 07-29-2011 10:02 AM
I'm getting ready to replace all the suspention components in the front end of y 62 Impala. Tie rods, balljoints, control arm bushngs and so on.
Originaly the car had an inline 235 and I swapped it to a SB 350. It apears to sit okay but I'm not sure if I should replace the coil springs. If I'm going to have this all apart I want to know if I need to swap the springs? Perhaps they are tiered as they are original but is there a differance from 6 cyl to an 8?
Deuce 07-30-2011 04:38 PM
The old 6 cylinder most likely weighed MORE than your 350 SBC with the aluminum intake and tube exhaust. Plus the SBC is further back than the longer 6 cylinder. I have done the 6 cylinder to SBC changeover many times in 55 to 57 Chevrolet's and a few 68/72 Chevrolet Novas and never HAD to change the springs. IF ... it sits like you like it ... I most definitely would not change the coil springs.
Tony@AirRideTech 08-02-2011 10:40 AM
Originally Posted by Deuce
The old 6 cylinder most likely weighed MORE than your 350 SBC with the aluminum intake and tube exhaust. Plus the SBC is further back than the longer 6 cylinder.[/B]
Yup... exactly what he said....
itsandre 08-02-2011 11:05 AM
Cool, save me some cash. It does sit nice in the front. The rear I might add air shocks to lift it just a bit after I replace the rubber frame mounts that are allsqwished. Want it to look old school hot rod.
I have all the parts for the front end including control arm bushings. Never done those before. Hope they's ain't to bad to do.
Thanks guys
