Front coil springs 62 impala - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-29-2011, 09:02 AM
itsandre's Avatar
I'm getting ready to replace all the suspention components in the front end of y 62 Impala. Tie rods, balljoints, control arm bushngs and so on.
Originaly the car had an inline 235 and I swapped it to a SB 350. It apears to sit okay but I'm not sure if I should replace the coil springs. If I'm going to have this all apart I want to know if I need to swap the springs? Perhaps they are tiered as they are original but is there a differance from 6 cyl to an 8?
Old 07-30-2011, 03:38 PM
The old 6 cylinder most likely weighed MORE than your 350 SBC with the aluminum intake and tube exhaust. Plus the SBC is further back than the longer 6 cylinder. I have done the 6 cylinder to SBC changeover many times in 55 to 57 Chevrolet's and a few 68/72 Chevrolet Novas and never HAD to change the springs. IF ... it sits like you like it ... I most definitely would not change the coil springs.
Old 08-02-2011, 09:40 AM
Originally Posted by Deuce
The old 6 cylinder most likely weighed MORE than your 350 SBC with the aluminum intake and tube exhaust. Plus the SBC is further back than the longer 6 cylinder.[/B]
Yup... exactly what he said....
Old 08-02-2011, 10:05 AM
itsandre's Avatar
Cool, save me some cash. It does sit nice in the front. The rear I might add air shocks to lift it just a bit after I replace the rubber frame mounts that are allsqwished. Want it to look old school hot rod.
I have all the parts for the front end including control arm bushings. Never done those before. Hope they's ain't to bad to do.
Thanks guys
81 c10 front coil springs swap for s-10 springs campracing Suspension - Brakes - Steering 3 10-05-2009 04:51 PM
front coil springs cosmictbird Suspension - Brakes - Steering 2 07-18-2008 05:13 AM
Front coil springs BinderRod1939 Suspension - Brakes - Steering 3 04-04-2004 01:12 AM
Front Coil Springs Cecil Stainback Engine 0 10-10-2003 08:52 AM
front coil springs 92 power ranger Hotrodders' Lounge 0 07-12-2003 07:55 PM
